I have googled and noticed that almost every Boeing 777 is not equipped with winglets. Does anybody know the reasons why Boeing did not equip B777s with winglets? Are there any drawbacks to having winglets?
As in anything in aviation design, the use of wingtips has both advantages and disadvantages. In the end, the decision to use (or not) a winglet is based on the cost-benefit analysis of the winglet to be used in that particular aircraft.
All winglets incur a drag and weight penalty- the question is whether they conserve fuel more than they increase it in the first place.
One problem in winglet addition is that they are prone to flutter.
Also, an equal span extension is sometimes more effective and is less risky.
Another thing to add is that most of the present aircraft using winglets (A320s and B737s) were not designed with winglets to begin with. They were retrofits. Most of the new aircraft are designed with plenty of aerodynamic experience and the engineers can take a call based on the data available as to whether to have 'conventional' winglet or not (See A350XWB Vs B787).
Coming to B777, it should be noted that the -300ER, -200LR, and -200F have wingtip devices after all- raked wingtips. These act in the same manner as the winglets to reduce drag.
Boeing 777 raked wingtip; image from Boeing.com
According to Boeing,
Each wing on the Boeing 777-300ER (extended range) is being extended by 6.5 feet, and raked wingtips are being added to improve the overall aerodynamic efficiency. The raked wingtips help reduce takeoff field length, increase climb performance and reduce fuel burn.
So basically, these act in the same manner as the conventional wingtips. Also, it is crucial to consider the tradeoff. B777 was designed when the advantages of the wingtips were well known, yet they decided to go without one anyway. From airspacemag:
Because winglets are a tradeoff: In the highly visible case of the 777, an airplane with exceptionally long range, the wings grew so long that folding wingtips were offered to get into tight airport gates.
Finally nobody ordered the folding wingtips when they were first offered, though that has not stopped Boeing from trying. Note that one main reason for offering folding wings is to fit into existing gates- else the wingspan would've become too great.
Boeing considered all the options before deciding to go with this option:
Dave Akiyama, manager of aerodynamics engineering in Boeing product development, points out that designing winglets can be tricky-they have a tendency to flutter, for example. "We find that it really doesn't matter what kind of wingtip device you use-they're all like span," he says. "The devil is in the details. Span extensions are the easiest and least risky."
And finally, winglets were considered for B777, especially for the earlier versions, though nothing came out of that- so most probably they were of not much use in improving fuel burn. Note that 787 also has a similar 'raked' wingtip instead of winglet.
Note: The fuel burn can be reduced by other means than wingtip devices- Boeing did exactly the same through Performance Improvement Package (PIP) for the Boeing 777, improving fuel burn by 1%:
... for long-range 777s, with United, Continental, and Delta investing in modifying the outboard aileron droop and the environmental control system, making ram air improvements, and installing smaller wing vortex generators to yield a total of 1 percent fuel burn improvement.
$\begingroup$ That is very kind of you. Many thanks to your crystal-clear answer. $\endgroup$ Sep 15, 2016 at 9:50
$\begingroup$ 747-8 is also a well-known user of raked-wingtips $\endgroup$– PeterSep 15, 2016 at 11:44
1$\begingroup$ Only the 300ER and the 200LR have the raked wingtips. $\endgroup$ Sep 15, 2016 at 11:48
$\begingroup$ One thing I'd add to this: when the 777 was released, it had an unusually long wingspan compared to most aircraft in service. Since then, the number of 777, 747, A380 and other long wingspan aircraft has meant there are plenty more gates available to handle the increased wingspan $\endgroup$ Sep 15, 2016 at 12:31
Another potential drawback to winglets is that of gate spacing at the ramp. Winglets can make for a much larger footprint at the gate. This could, in turn, make 5 airplanes without winglets into 2-3 planes with winglets, depending on spacing requirements and availability.
You might be saving on gas for long haul routes, but if you’re only hauling 50% of your passengers and/or freight because you can’t stuff enough airplanes into “Airport X,” then you’re not really saving on much in the first place.
$\begingroup$ It seems you are confusing winglets (vertical extension) with wingtips (horizontal extension), as winglets do not add much to the width of a plane. Also you are answering a question thats over a year old. $\endgroup$– MadMarkyMar 29, 2018 at 10:35
$\begingroup$ No confusion. In order for winglets to go up, they have to go out as well. On the 757, for example, it was drastic enough (13 feet of extra clearance on each side, if memory serves) for my operator to opt out of winglets entirely as it would have required an extraordinary amount of extra gates. I don’t remember the exact number, but I believe it was something like 20 fewer overall aircraft. The difference between lost lift vs. fuel savings on short routes wouldn’t have added up. So, yes, it is a significant factor. Sorry for the thread necromancy. $\endgroup$– FrankMar 29, 2018 at 15:01
$\begingroup$ Out of curiosity, was your "operator" an airline or an airport or something else? Usually an airline would be considering which aircraft to order whereas an airport would be considering how to lay out their gates. Your comment implies consideration of both by one entity which isn't something I've come across before. $\endgroup$– jbgApr 9, 2019 at 4:52
