I'm an aerospace engineering PhD student and for my research I'm investigating how to come up with a way to pick the most critical flight conditions for flutter. The main idea is to understand how it is currently done in industry and expand that approach for nonlinear cases.
I've been scouting the web to find information on how companies do that (Airbus, Boeing, Embraer etc.) but I was only able to find a paper from Dassault (A Review of Industrial Aeroelasticity Practices at Dassault Aviation for Military Aircraft and Business Jets) that briefly describes their practices for flutter, without really answering my question.
FAR 25 (hence same for EASA) in AC 25.629-1B (the "extension" of part 25.629, which is dedicated to flutter) states that:
For nominal conditions without failures, malfunctions, or adverse conditions, freedom from aeroelastic instability is required to be shown for all combinations of airspeed and altitude encompassed by the design dive speed (V_D) and design dive Mach number (M_D) versus altitude envelope enlarged at all points by an increase of 15 percent in equivalent airspeed at both constant Mach number and constant altitude. The figure below represents a typical design envelope expanded to the required aeroelastic stability envelope. Note that some required Mach number and airspeed combinations correspond to altitudes below standard sea level.
So does anybody know whether designers only pick a few points at the boundaries of the envelope to actually check for flutter? Or something else is done? For example, in the case of the envelope above this would mean running a velocity-based linear flutter search for several mach numbers between C'' and B'.
Thanks everyone!
