F 104 V-n diagram
In this V-n diagram for an F-104 (source: this Wikipedia link), on the left-hand edge of the flight envelope, what is causing the "corners" that we see at the following points? (Numbers are approximate)
30,000', 375 knots IAS, and 5 G
40,000', 295 knots IAS, and 3.1 G
50,000', 230 knots IAS, and 2 G
60,000', 180 knots IAS, and 1.25 G
70,000', 140 knots IAS, and 0.95 G
Do these points simply represent the "corners" of what performance is possible while still maintaining horizontal flight at a constant airspeed (i.e. while maintaining both altitude and airspeed), and if more engine thrust were available, these "corners" would move higher up and to the right, continuing to follow the stall speed curves? I.e., do the actual stall speed curves continue upward from the corners following a path that is more or less continuous with the lines below the corners?
(Note-- re the last data point-- a G-loading of less than 1 is obviously incompatible with constant-altitude flight-- but the data point still could have mathematical or theoretical significance -- e.g., if the aircraft weight decreased by 5%, then the aircraft could maintain constant altitude.)
Wouldn't it be theoretically possible for a pilot to operate well outside the illustrated envelope, say, by pulling 4G at 340 knots IAS at 40,000'? Am I correct to assume that this could be done without stalling the aircraft, but the aircraft would be losing either altitude or airspeed continually? Because it is on the "back side" of the thrust-required curve? Whereas that would not be the case for a point further to the right, on the other side of the illustrated curve?
If the actual stall speed curves do in fact continue more or less smoothly upward from the "corners", this would imply that if, theoretically, we were setting a "maneuvering speed" to protect the aircraft from exceeding 6G's, it would need to be at about 430 knots IAS at 20,000' (the "cornering speed" shown on the diagram), but it would need to drop to about 380 knots IAS at 30,000' -- well outside the envelope of the figure as drawn. Is this in fact the actual situation?
Is this particular diagram really as much about achievable performance as about protecting the aircraft from excess loading, at least in the positive-G part of the flight envelope?
Is it therefore not strictly accurate to call this particular diagram a "V-n diagram"?
Related ASE questions and answers--
(Q): In this F-104 V-n diagram, why does the stall speed (in terms of IAS) decrease with altitude in some parts of the flight envelope?
    $\begingroup$ boldmethod.com/learn-to-fly/aerodynamics/… $\endgroup$
    – MD88Fan
    Apr 17, 2021 at 16:17
  • $\begingroup$ @ymb1 -- lots of tags deleted there (edit #12), was that all really necessary? Especially as the thrust of this question was that the answer might in fact have a great deal to do with aircraft performance. And physics is a pretty broad brush that would seem to include this question. $\endgroup$ Apr 17, 2021 at 18:20
  • $\begingroup$ @quietflyer responded in chat $\endgroup$
    – user14897
    Apr 17, 2021 at 18:23
  • $\begingroup$ @Vikki-formerlySean -- the problem with including that last "corner" is that it plays havoc with my question "Do these points simply represent the "corners" of what performance is possible while still maintaining horizontal flight at a constant airspeed". Obviously horizontal flight cannot be sustained at less than 1.0 G. Therefore I will modify back to something closer to a previous edit that removed that "corner". $\endgroup$ Apr 18, 2021 at 0:47
  • $\begingroup$ @quietflyer: The problem with not including the last corner is that its existence invalidates your proposed reasoning for the corners - given that horizontal flight cannot be sustained at less than +1 G, the presence of a corner at less than 1 G means that those points cannot possibly be "the 'corners' of what performance is possible while still maintaining horizontal flight at a constant airspeed". $\endgroup$
    – Vikki
    Apr 18, 2021 at 0:55
12
Compressibility. Close to Mach 1 the lift curve slope increases according to the Prandtl-Glauert rule with the factor $\frac{1}{\sqrt{1-Ma^2}}$. Since the X-axis shows indicated speed, the Mach 1 point moves left with increasing altitude. Technically, those corners should also be added for the negative lift limit.
Do these points simply represent the "corners" of what performance is possible while still maintaining horizontal flight?
No. A v-n-diagram covers the whole load factor range while horizontal, steady flight happens along the line y = 1g (except for turns or inverted flight, of course). Adding more thrust will not change the limits. Maneuvering is only possible/permitted (see below) inside the lines and maneuvering at constant altitude depends on thrust which is not included here. The lines show lift and structural limits; thrust envelopes look different.
Wouldn't it be theoretically possible for a pilot to operate well outside this envelope?
Not really. Momentarily yes, for example the stall lift coefficient moves up with higher pitch rate, but that only works while pitch angle is increasing. Also, at supersonic speed (after all, your example of 340 KIAS @ 40 kft is equivalent to Mach 1.07) the envelope is limited by angle of attack, not lift. Therefore, 4g at Mach 1.07 in 40 kft is outside of the permissible flight envelope but may be reached if the pilot overrides stick shaker and stick pusher (depending on control authority).
So this diagram is really as much about achievable performance as about protecting the aircraft from excess loading?
Yes. The region left of the stall lines is impossible to fly since lift is limited at lower speed. However, the top speed limit might well be exceeded in a dive if the pilot chooses to do so. Equally, the g limit might be exceeded right of the point where the envelope becomes horizontal.
Thank you @JanHudec for pointing out correctly that those areas which can physically be reached by improper flying but might incur damage to the airframe are colored red.
  • $\begingroup$ Comments are not for extended discussion; this conversation has been moved to chat. $\endgroup$
    – Federico
    Apr 19, 2021 at 5:28
    $\begingroup$ For the last point, you could note that the structural limits—where you can get by mishandling the plane, but risk damaging it—are marked with red on the diagram. $\endgroup$
    Apr 19, 2021 at 6:39
  • $\begingroup$ The answer still could be improved by modifying the statement "horizontal flight happens along the line y = 1g." $\endgroup$ Apr 19, 2021 at 14:05
  • $\begingroup$ @quietflyer You are right, in turns the load factor is greater than 1. When I wrote this I was only thinking of loops. $\endgroup$ Apr 19, 2021 at 16:54
