In the X-Z plane I have defined an airfoil shape using the function z = f(x). See figure 1. However, since the chord length of real airplane wings increases along the wingspan, I thought I needed to improve this function and found the following formula to describe the relationship between the tip chord, root chord, and wingspan:
$$x=\frac{\left(c_{root}-c_{tip}\right)}{\frac{b}{2}}y+c_{tip}$$
where $$c_{tip}=1\ \ \ c_{root}=3\ \ \ \ \ \ \ \frac{b}{2}=20$$
(The formulas shown are not important in figure 2. I just wanted to show the function f(x/(1+y/10)) but I can provide it to you if you want)
However, I first tried replacing x with 1+y/10 in my z = f(x) function, then I tried multiplying x with 1+y/10, but neither provided me with an accurate model. Later, instead of multiplying with x, I wrote it as $$f\left(\frac{x}{1+y/10}\right)$$ and it gave me figure 2. What I actually want to understand is the mathematical basis behind this phenomenon, that is, how could I express this situation in mathematical terms if I needed to?
I still don't know if this model is correct, because in figure 2 it seems to me that only the chord length has increased, but shouldn't the area of the airfoil increase? For example, when c = 1, Area = 2, and when c = 3, shouldn't Area = 6?
