Short answer
ICAO ATC phraseology is not mandatory, and is implemented by States members at different degrees, due to historical reasons:
ICAO ATC procedures, including phraseology, are not part of the standards and recommended practices (currently 12,000 SARP in 19 annexes), but of procedures for air navigation services (currently 6 PANS documents). PANS implementation is highly recommended, but is not mandatory.
Being not standards, ICAO State members may not list the local implementation differences in their aeronautical publications (AIP) at section GEN 1.7. However as PANS are important procedures, States usually give a summary of these differences in the subsection “PANS / Doc 4444”.
ICAO Convention is built on Paris Convention, managed between 1919 and 1944 by ICAN, the International Commission for Air Navigation. This convention was first intended to agree on sovereignty and security matters in European airspace, after the war. While ICAN was supported by the US, it was actively promoted by French Clemenceau and Albert Roper. It has been at the core of air navigation in Europe since then. When ICAO Convention was signed in 1944, Europe was already compliant, while other countries, including the US, had to manage important differences, and couldn't clear all of them easily.
Details follow.
ICAO standards
Collectively known as international SARP (standards and recommended practices), ICAO standards are adopted by ICAO Council and published as annexes to the ICAO Convention. They are intended to be included in each State member law. The Convention requires to enumerate which SARP have been adjusted or excluded locally (article 38), in the AIP of the State member, at section GEN 1.7.
ICAO Docs
ICAO Council also approves other practices, and recommend them. However because such practices are either not mature enough, contain too detailed elements subject to rapid change, or have a nature not compatible with the way the Council works, these practices are not given the status of standards. Instead of being published as annexes, there are published as “ICAO documents”.
State members have no legal obligation to use the procedures detailed in “Docs”, they only need to comply with the principles included in SARP. They have no obligation to explain in AIP GEN 1.7 how the local practices differ. However they are invited to do so.
ICAO PANS
In the area of ATC, the major documents are known as PANS (procedures for air navigation services), they include (links open directly pdf files):
Doc 4444, PANS-ATM (traffic management), merging previous PANS-ATC and PANS-RAC.
Doc 8168, PANS-OPS (aircraft operations) - Volumes I, II, III.
Doc 9868, PANS-TRG (training).
Doc 9981, PANS-ADR (aerodromes).
Doc 10066, PANS AIM (aeronautical information management).
Annex 10: SARP and PANS mixed
PANS-ATM are introduced by Annex 10, volume 2 (Communication Procedures including those with PANS status) which use is mandatory.
Annex 10, volume 2 provides both SARP and PANS for history reasons (PANS come from older Doc 7181, Radiotelephony Procedures, now superseded). SARP describe the principles to be used for communications and provide provide some phraseology details, which status is mandatory.
PANS are added to clarify details, but they are not mandatory. They are identified by the prefix PANS and written in italic. Examples:
5.2.1.5.8 The following words and phrases shall be used in radiotelephony [...]
CLEARED “Authorized to proceed under the conditions specified.”
UNABLE “I cannot comply with your request, instruction, or clearance.”
5.2.1.7.3.2.6.1 PANS.— As the aircraft may be guarding more than one frequency, the initial call should include the distinctive channel identification “INTERPILOT”.
Publication of differences with PANS
Explaining the differences with PANS-ATM is not mandatory. From Doc 4444:
5.1 The PANS do not carry the status afforded to Standards adopted by the Council as Annexes to the Convention and, therefore, do not come within the obligation imposed by Article 38 of the Convention to notify differences in the event of non-implementation.
However State must take it into consideration because:
5.2 However, attention of States is drawn to the provision of Annex 15 related to the publication in their Aeronautical Information Publications of lists of significant differences between their procedures and the related ICAO procedures.
FAA ATM procedures are described in JO 7110.65. As ATM procedures are critical, the major differences are actually included in GEN 1.7. Examples:
Doc 4444:
4.6.3.2 An arriving aircraft may be instructed to maintain its “maximum speed”, “minimum clean speed”, “minimum speed”, or a specified speed.
FAA:
The U.S. uses different speed control phraseologies. Specifically, Doc 4444 uses “Maximum Speed” whereas the US uses “Maximum Forward Speed”. Doc 4444 uses “Minimum Clean Speed” whereas the US uses “Slowest Practical Speed.”
Doc 4444:
12.4.2.4.2 a) COMMENCE DESCENT NOW [TO MAINTAIN A (number) DEGREE GLIDE PATH]
FAA:
The U.S uses only “begin descent” and does not speak to “Maintain a (number) Degree Glide Path.”
Other documents related to ATC phraseology
- Doc 9432 (manual of radiotelephony) has the same status as PANS, it is not a standard, only recommendations.
European countries and US approaches
There are different approaches regarding the implementation of ICAO Docs. Certains States are more inclined to implement them than other, in particular European countries.
The Chicago Convention (1944) is directly based on Paris Convention (1919), a convention managed by the International Commission for Air Navigation (ICAN). ICAN was active between 1919 and 1944, it transitioned to a UN agency between 1944 and 1947 (OPACI), then became ICAO.
ICAN was impulsed in Paris at the end of WWI, with the support of the US, to deal with sovereignty of airspace.
Since 1919, ICAN/ICAO have been the core of the standardization process for international air navigation in most European countries. Remote from Europe sovereignty problems and less involved in ICAN, the US standardized their practices differently. Merging with ICAO recommendations is indeed more difficult, and done when it's worth the effort required from FAA, crews, ATCOs, etc.
