Is it common for pilots to breach separation standards in terminal airspace while the conditions are VMC? I'm interested primarily in commercial aircraft that have scheduled operations in major airports.
I know there are Loss of Separation events reported to FAA - is that a small subset of actual incidents? Are these reports predominantly for during IMC conditions?
    $\begingroup$ What do you mean? There are no separation minima for pilots to follow, only for controllers. Depending on airspace class, either ATC needs to provide separation - and does so - or not. Pilots are never responsible for ensuring ATC separation $\endgroup$ Oct 17, 2020 at 19:32
  • $\begingroup$ The question in the title doesn’t really match the question body, can you say more precisely what you’re looking for? And can you clarify what you mean by “terminal airspace”? The ATC separation services are different in different airspace classes. For example, ATC (in the US) separates all traffic in class B, but not in C/D. $\endgroup$
    – Pondlife
    Oct 17, 2020 at 20:34
  • $\begingroup$ I guess by terminal airspace I was referring to class B airspace. So, I calculated distance between aircraft pairs 50 nautical miles around DFW from flight track data. The distances calculated fall under the prescribed separation standards. And it happens more during VMC conditions (based on ceiling and visibility values). I guess my question is whether this loss of separation is expected? $\endgroup$ Oct 17, 2020 at 23:06
    $\begingroup$ @distributedconscious - I am in the DFW area. During VMC, ATC will confirm that aircraft are in visual contact with each other. They will then inform pilots to maintain visual separation. No exact distances are prescribed. When a pilot acknowledges they have visual contact, it is then up to the pilot to “see and avoid”. If the pilot is within the 30 mile mode C veil, but outside (under) the Class B airspace, the pilot can fly VFR without ATC services. In non-participating VFR flight, the pilot is solely responsible for separation. ATC will separate non-participating from participating. $\endgroup$
    – Dean F.
    Oct 18, 2020 at 1:17
    $\begingroup$ @distributedconscious - Participation in ATC separation services is strictly voluntary outside (under and around) the DFW Class B. If you are going to enter the Addison (KADS) airspace, you have to participate in DFW separation services provided by TRACON 10 until handed off to the Addison Tower. Otherwise, if you are a pilot in command of a non-participating flight, you are responsible to see and avoid other traffic. A lot of the flights you are seeing on Flight Radar and other services may be GA aircraft flying in VFR. That may be why you see a difference during IMC. $\endgroup$
    – Dean F.
    Oct 18, 2020 at 1:33
There are several different separation standards which ATC attempts to maintain between aircraft. Note that only one of the standards below needs to be maintained; if one is valid that is sufficient. I'm answering for USA-land as you mention the FAA in your question.
Vertical Separation
Aircraft may be separated vertically. If one aircraft is directly above a point on the earth and is at an altitude of 4000 feet, and another aircraft is directly above the same point at an altitude of 6000 feet, they are separated.
IFR aircraft must be separated from other IFR aircraft by at least 1000 feet. At or above FL290 this increases to 2000 feet if either aircraft is not Reduced Vertical Separation Minima-capable (RVSM), and above FL410 the minimum is 2000 feet no matter what (and sometimes more for certain military or supersonic flights).
Within Class B, Class C and TRSA airspace, IFR aircraft are separated from VFR aircraft by at least 500 feet. This also applies to known VFR aircraft operating in the associated Class C outer area.
Within Class B and TRSA airspace, VFR aircraft are also separated from other VFR aircraft by at least 500 feet. VFR aircraft must receive an explicit clearance into Class B airspace, allowing them to be separated from other VFR aircraft. In the case of a TRSA this only applies to aircraft requesting radar services.
Lateral Radar Separation
Vertical separation is not terribly interesting. Let's instead look at lateral separation, where the two aircraft are at the same altitude, so it would not be good if they were also above the same point on the earth.
The absolute bare-bones basic standard of separation is: Did the planes hit each other? This is a highly undesirable situation. For VFR aircraft operating in Class E/G airspace, this is the only minimum that matters, and pilots will apply it themselves using the "see and avoid" principle: They see other aircraft and maneuver to avoid hitting them. This is also the only separation standard that ATC maintains between two VFR aircraft in Class C/D/E airspace, and in fact separation isn't truly lost until the planes trade paint. (Then it's a bad day for everyone.)
At a slightly higher level there is target resolution. This can be applied between VFR-VFR or VFR-IFR aircraft operating in any type of airspace, except in Class Bravo when one aircraft weighs more than 19,000 lb or is a turbojet. Target resolution means the controller issues instructions, traffic advisories, and safety alerts to ensure that the radar targets on their screen are "resolved," which is to say they do not ever touch each other. There can be some error in the positioning of the targets on the screen but if two aircraft are very near each other the difference between the two errors is likely to be minimal—so if the displayed targets never touch, you can be sure the aircraft themselves certainly don't.
Getting into defined radar separation:
  • In Class Bravo airspace, VFR aircraft are separated from IFR/VFR aircraft weighing more than 19,000 lb by 1.5 nautical miles.
  • In the terminal environment (i.e. TRACONs, and enroute facilities at FL230 and below where certain requirements are met) IFR aircraft are separated by 3 NM. This can be reduced to 2.5 NM on final approach, subject to various extra rules and procedures.
  • If the aircraft is more than the prescribed distance from the radar antenna, or if the system indicates a need, or above FL230, IFR aircraft are separated by 5 NM.
  • At or above FL600 separation increases to 10 NM between IFR aircraft.
Passing or Diverging Separation
Terminal facilities are authorized to discontinue the use of radar separation and fall back on target resolution if aircraft are on tracks which will never meet (either because one target has passed the projected track of another, or if they are opposite-direction because the two targets have passed each other). Enroute facilities can do this as well but have more onerous rules.
Wake Turbulence Separation
Smaller aircraft operating behind heavier aircraft (defined based on maximum takeoff weight) are afforded increased separation, ranging from 4 to 10 NM instead of 3 or less.
Non-Radar Separation
Almost invariably, using non-radar separation will provide a greater actual distance between aircraft than using radar separation, so it is not usually applied in areas of radar coverage. For myself I don't know much about it, having never applied it.
Lateral
Aircraft may be separated by assigning them to fly on different airways, or different radials or arcs of navigational beacons, or other such procedures.
Longitudinal
Aircraft operating along the same airway, or at the same airport, may be separated based on time and speed.
Visual Separation
Airborne separation may be reduced below the applicable minimum if visual separation is used. Some other form of approved separation must exist before and after the application of visual separation, and visual separation is not allowed above FL180 (i.e. in Class A airspace) or if the leading aircraft is a super weight class.
Pilot-applied visual separation may be used if the pilot of one aircraft reports another aircraft in sight and confirms that they will maneuver to maintain their own separation (i.e. they don't hit). Tower-applied visual separation may be used if the tower controller can see both aircraft and issues instructions to ensure they don't hit.
Visual separation is not prohibited if the weather is below VFR minima (IMC) but will likely have limited usefulness because some other form of approved separation must exist once the pilot or controller loses sight of the aircraft. Some facilities have it written in their local procedures that tower-applied visual separation is assumed to be in effect whenever the weather is better than certain minima.
Runway Separation
Not as relevant to your question but provided for completeness. Runway separation is flight-rules agnostic; the controller will apply it regardless if a flight is VFR, SVFR, or IFR. Based on the category of aircraft (category being defined in relation to engine type and number, and for single-engine propeller planes also weight) and type of operation (arrival-arrival, arrival-departure, departure-arrival, departure-departure) ATC will ensure 3000, 4500, 6000 or "the entire runway's worth" feet between aircraft operating on the same runway. They will also ensure an aircraft or vehicle does not cross a runway another aircraft is operating on.
So to finally answer your question: Pilots do not apply "separation standards" in any type of airspace, except that they are required to avoid hitting other aircraft if they see them in time. Instead, ATC applies separation minima which change based on the type of flight rules, type of aircraft, and airspace in which the aircraft is operating. In order to make sure these separation minima are maintained, pilots are required to comply with ATC clearances and instructions, or else have a really good reason why not.
  • $\begingroup$ Why does the required IFR-IFR separation double above FL600? $\endgroup$
    – Vikki
    Mar 9, 2021 at 23:23
    $\begingroup$ @Vikki, probably for the same reason separation increases from 3 to 5 NM at FL230. I'm not certain what that is, but it's probably because aircraft operating at higher altitudes will tend to have faster groundspeeds so you want more wiggle room in case separation is lost. Also higher aircraft will by necessity be farther from the antenna (which measures slant-line distance) so will have more uncertainty associated with their position... though 60,000 feet is only 10NM, so not a huge difference compared to the 290-mile range of an air-route surveillance radar. $\endgroup$
    – randomhead
    Mar 9, 2021 at 23:49
The only “separation standard[] issued by ATC” is visual separation, and as long as you don’t literally hit the other plane, you have complied with it. The penalty for non-compliance is usually death, so we pilots take that pretty seriously.
All other types of separation are provided by ATC via some sort of clearance or instruction that the pilot must comply with. If not, the pilot can be violated (which might mean a fine or license suspension) for failure to obey said clearance or instruction, not for any resulting loss of separation per se.
In practice, a loss of separation usually happens because some non-participating aircraft suddenly wanders into the path of a participating one. That shouldn’t happen in class A/B/C/D since non-participating aircraft shouldn’t be there in the first place, but it does happen now and then when someone gets lost; it’s fairly common in class E/G, where participation is optional.
