In this question, it states that the ram air turbine (RAT) deploys automatically on Airbus aircraft when there is a dual engine failure. Is there a way to stow the RAT in case systems are recovered and the RAT is no longer needed while the aircraft is airborne or does it have to be stowed by ground personnel? Are there differences between Boeing and Airbus aircraft insofar as deployment and stowage are concerned?
    $\begingroup$ On the CRJs the thing is under the nose below the right seater's feet and runs a fixed freq ac generator. It's extended by a spring strut when both main ac buses are depowered. It's retracted by a hydraulic hand pump. I've done test extensions and the noise the thing makes is unbelievable. It sounds like a giant woodworking router under the floor. $\endgroup$
    Commented Mar 27, 2023 at 19:09
  • $\begingroup$ @John K-Is the hydraulic retraction of the RAT on the CRJ done by the aircrew or ground maintenance personnel? $\endgroup$
    – RetiredATC
    Commented Mar 27, 2023 at 20:18
  • $\begingroup$ Normally by ground maintenance. An airline crew would never do it in a million years anyway; they generally won't use the oil replenishment system either (you can top up the engine oil from a tank in the tail section). But a corporate crew might, if they were stuck at a remote area and needed to stow it to get away. You need the Maint Manual procedure to do it. Not sure if a maint log book entry is required if it's been deployed and restowed. $\endgroup$
    Commented Mar 27, 2023 at 21:49
    $\begingroup$ @JohnK I added a quote from the CRJ electrical description to my answer. It says "It is restowed manually, on the ground, by maintenance personnel." $\endgroup$
    – Bianfable
    Commented Mar 28, 2023 at 8:00
The RAT is typically deployed using a spring loaded lever and cannot be stowed in flight. See this question for more details on deployment: How do Ram Air Turbines get deployed?
There is no fundamental difference between the implementations of Airbus, Boeing or Bombardier. I will quote some relevant sections of a few flight manuals here:
  • Airbus A320:
    Ram Air Turbine (RAT)
    A drop-out RAT coupled to a hydraulic pump allows the blue system to function if electrical power is lost or both engines fail. The RAT deploys automatically if AC BUS 1 and AC BUS 2 are both lost. It can be deployed manually from the overhead panel. It can be stowed when the aircraft is on the ground.
    (Airbus A320 FCOM - Hydraulic Description, italic emphasis mine)
  • Boeing 777:
    The RAT, when deployed, provides hydraulic power only to the primary flight control components connected to the center hydraulic system. The RAT provides hydraulic and electrical power throughout the flight envelope. In flight, the RAT deploys automatically if:
    • both engines are failed and center system pressure is low, or
    • both AC transfer busses are unpowered, or
    • all three hydraulic system pressures are low
    The RAT can be deployed manually by pushing the RAM AIR TURBINE switch. The hot battery or APU battery bus must be powered. The RAT is deployed by a compressed spring. Once deployed, the RAT cannot be stowed in flight.
    (Boeing 777 FCOMv2 - 13.20.3 Hydraulics - System Description, italic emphasis mine)
  • Bombardier CRJ:
    Air Driven Generator (ADG)
    In the event of a complete AC power failure in flight, the ADG will automatically deploy and supply emergency AC power to the ADG bus and to the AC essential bus. If the automatic deploy function fails, the ADG can be deployed manually by pulling the ADG manual release handle on the ADG CONTROL control panel at the rear of the center console. [...]
    The ADG cannot be restowed in flight. It is restowed manually, on the ground, by maintenance personnel.
    (Bombardier CRJ FCOM - Electrical - AC Electrical System, italic emphasis mine)
To stow the A320 RAT on the ground, the blue hydraulic system must be pressurized (via the electric pump) and the RAT EXTN SOL1 circuit breaker must be pulled. The RAT control panel is on the blue ground service panel. The RAT is stowed with STOW switch like this:
A320 RAT stowage
(YouTube: AIRBUS A320 RAM AIR TURBINE EXTENTION)
  • $\begingroup$ As you can see on the Airbus, stow is electrically controlled. The fundamental reason why retraction has to be done by a mechanic on the ground is they have to align the RAT blades with the orientation of the compartment. $\endgroup$
    – user71659
    Commented Mar 28, 2023 at 1:22
  • $\begingroup$ @user71659 Well, if they really wanted to, they could install a mechanism that allows stopping the blades in the correct position and then retract it via a button in the flight deck. There is just no need for that. $\endgroup$
    – Bianfable
    Commented Mar 28, 2023 at 7:49
