The 777X family (777-8/-9/-10) features wingtips that fold up on the ground to let the aircraft fit in tight spaces. These have to be extended and locked in place before a revenue flight can take place, but can a 777X legally be ferried with one or both wingtips in the folded position - for instance, if one of the wingtips is jammed in the up position while at some backcountry airport that doesn't have maintenance facilities for a 777?
For the purposes of this question, I'm assuming that it's physically possible to operate the aircraft. The non-folding part is the same length as the wing of a regular 777, so it would still be able to take off safely, just with considerable performance penalties compared to normal, wingtips-folded-down flight. Ferry flights for maintenance purposes can get away with a lot that wouldn't be allowed during line operations (for instance, multi-engine jetliners can be ferried with one engine - or, for quadjets, two - inoperative, and the 747-400 can be ferried with one of its winglets broken off).
