Pilotweb lists NOTAMs currently in effect. Is it possible to view or sort the history for a particular airport?
1 Answer
On Pilotweb, there's a "Federal NOTAM System (FNS)" section on the right side of the screen. If you select "NOTAM Search" it takes you to another NOTAM search tool. If you then select "Archive" from the drop-down list, you can search by date and location.
$\begingroup$ Thank you, I clicked the arrow and it turned green on my iPad. Hope that credits a correct answer. $\endgroup$– JavelinFeb 14, 2019 at 4:30
