Is there any source that provides more details on Saint-Exupéry's desert crash in 1935 than Wikipedia does:
On 30 December 1935, at 2:45 a.m., after 19 hours and 44 minutes in the air, Saint-Exupéry, along with his mechanic-navigator André Prévot, crashed in the Libyan desert, during an attempt to break the speed record in a Paris-to-Saigon air race and win a prize of 150,000 francs. The crash site is thought to have been near the Wadi Natrun valley, close to the Nile Delta.
I find hard to understand how flying for nearly 20 hours between Paris and Saigon can lead any plane to as short distance as middle Libya?
Google Maps shows a distance of approx. 1950 miles straight line between Paris and Wadi Natrun, which gives us nearly exactly 100 mph of speed, which is only half of Caudron Simoun's speed.
What am I missing? Is it / was it a regular practice to fly "that slow" on such large distances?
There are 6000 more miles to fly between Wadi Natrun and Saigon, according again to Google Maps. With 100 mph we have 60 hours of flight plus additional 20 hours already flown. Which gives us a total distance of 8000 miles or 80 hours with this speed. Was there any aircraft and pilot, in 1935, able to manage such trip, even assuming breaks in flight for fuel refilling and resting?
    $\begingroup$ Wikipedia shows the 1935 speed record as much higher: 13 September 1935, Howard Hughes, 354.4 mph, 567.12 kmh, Hughes H-1 Racer landplane. I don't know what range it had tho. $\endgroup$
    – CrossRoads
    Commented Oct 11, 2018 at 11:41
    $\begingroup$ And more: Hughes later implemented minor changes to the H-1 Racer to make it more suitable for a transcontinental speed record attempt. The most significant change was the fitting of a new, longer set of wings that gave the aircraft a lower wing loading. On January 19, 1937, a year and a half after his previous landplane speed record in the H-1, Hughes set a new transcontinental speed record by flying non-stop from Los Angeles to New York City in 7 hours, 28 minutes and 25 seconds. $\endgroup$
    – CrossRoads
    Commented Oct 11, 2018 at 12:18
    $\begingroup$ From the Smithsonian Air and Space Museum: His average speed over the 2,490-mile course was 332 mph, and this nonstop flight was truly an outstanding accomplishment. $\endgroup$
    – CrossRoads
    Commented Oct 11, 2018 at 12:25
  • $\begingroup$ @CrossRoads I have a trouble understanding what are you talking about, maybe due to lack of link / cite. How can his course be 2490 files, if they crashed after 1950 mile flight? How can his average speed be 332 mph, if they flown 2000 miles in 20 hours so their average speed, as per my calculation, is around 100 mph. Are we talking about the same flight? $\endgroup$
    – trejder
    Commented Oct 14, 2018 at 17:05
    $\begingroup$ The 332 mph/2490 miles refers to Howard Hughes' flights, in reference to the last question of the original post about any aircraft being able to make the flight. $\endgroup$
    – CrossRoads
    Commented Oct 14, 2018 at 21:13
This site has more details on why it took so long to get to Libya
https://www.thisdayinaviation.com/30-december-1935-wind-sand-stars/
After taking off at Paris, Saint Exupéry followed the Seine to the valley of the Loire and continued south, crossing the southern coast of France near Marseilles. The fliers had been over the Mediterranean Sea for a short while when they saw fuel leaking from the left wing. Prévot calculated that they had lost 20 gallons (76 liters) of fuel. They turned back and landed at Marignane to repair the leak and refuel before continuing. Saint Exupéry wrote, “I drank a cup of coffee while the time lost hurt like an open wound.”
Once again heading across the Mediterranean toward Tunis, they encountered low clouds and heavy rain which forced them down to just 60 feet (18 meters) over the water. They flew along the coast of Sardinia as the weather improved.
F-ANRY crossed the coast of Africa at Bizerte, Tunisia, and about fifteen minutes later landed to refuel. With two hours of daylight remaining, Saint Exupéry and Prévot took off again, now heading toward Benghazi, Libya. They landed there at 11:00 p.m., local time, and in just twenty minutes the airplane had been refueled and once more, they were airborne.
Flying east after moonset, Saint Exupéry and Prévot were in total darkness. After three hours a faint glow of his navigation lights on the airplane’s wingtips told Saint Exupéry that he had flown into clouds, with visibility measured in just feet.
At a time when there were no navigation aids, pilots had to navigate by their compass, airspeed indicator and clock. Though Saint Exupéry had met with meteorologists to plan his flight, there was no way to update the weather information after takeoff. He had no way of knowing whether an expected tailwind had held, or if it had changed; was his speed across the ground faster or slower than planned? Had the wind blown him right or left of course? Had the atmospheric pressure changed, causing his altimeter to read higher or lower than the airplane actually was? Flying across the emptiness of the Sahara Desert with no landmarks, in total darkness and now just a few feet of visibility, he and Prévot could only guess at their position.
4 hours, 15 minutes after taking off from Benghazi, the C.630 crashed into gently rising terrain at 170 miles per hour (274 kilometers per hour).
More on the plane:
The Société des Avions Caudron C.630 Simoun was a four-place, single-engine, low-wing monoplane with fixed landing gear. It was built of wood, with the surface of the wings and fuselage covered in plywood sheet then covered with doped fabric. Carefully curved aluminum sheet metal covered the top and bottom of the fuselage. The C.630 was 8,70 meters (28 feet, 6½ inches) long with a wingspan of 10,40 meters (34 feet, 1½ inches) and height of 2,25 meters (7 feet, 4½ inches). The airplane’s gross weight was 1,230 kilograms (2,712 pounds).
The engine was an air-cooled, normally-aspirated 9.500 liter (579.736 cubic-inch-displacement) Renault Bengali 6Pri inverted inline six-cylinder overhead-valve (OHV) engine rated at 180 cheval vapeur (177.5 horsepower). The left-hand-tractor, direct-drive engine turned a two-bladed, metal Ratier variable-pitch propeller. The propeller could be set to coarse pitch by a mechanic prior to takeoff, then an air bladder mechanism could change it to fine pitch for cruise flight.
The C.630 had a maximum speed of 310 kilometers per hour (193 miles per hour). The service ceiling was 7,500 meters (24,606 feet) and normal range was 1,260 kilometers (783 miles). Twenty C.630s were built before production changed to the slightly improved C.631.
Not a lot different than my Cessna Cardinal, which is a little wider (35'6"), 4 seats, fixed gear, and 180 HP Lycoming engine with constant speed (variable pitch) prop totally controlled from within the cockpit. Service ceiling only 14,600 feet (altitude where climb rate drops to under 100 ft/min). Gross weight 2,500 lbs. Max speed (never exceed speed) is 192 mph, with max cruising speed of 158mph (speed not to exceed except in smooth air). Cardinal carries less fuel most likely, just 50 gallons, my best range at 10,000 ft is 615 miles. I think our longest flight has been about 4 hours, can only listen to ATC for so long!
    $\begingroup$ There is no information (neither in your answer nor in the cited text) on how much it took them for repairs of leaking fuel tank and refuelling, but I assume that this could take a couple of hours and cause the medium trip speed to be that low. Thank you for providing all these details. $\endgroup$
    – trejder
    Commented Oct 12, 2018 at 12:41
