I think the controller sometimes gives altitudes for VFR traffic to fly, but do pilots actually need permission to change their altitude?
$\begingroup$ Which country or regulations are you asking about? $\endgroup$– PondlifeCommented Jul 3, 2018 at 13:00
$\begingroup$ The US, thanks. $\endgroup$– slantalphaCommented Jul 3, 2018 at 13:05
$\begingroup$ In Bravo, where you are cleared in, and the area is large, I would say yes. In Charlie or Delta, it would depend on how much other traffic was around. $\endgroup$– CrossRoadsCommented Jul 3, 2018 at 13:55
1$\begingroup$ The question should NOT be marked as a duplicate: you should have a clearance in a controlled airspace (except E for VFR) regardless of whether you requested flight following or not. But the answer is really pretty much the same as during the flight following: it depends on airspace class and ATC instructions, and you should always follow ATC instructions. $\endgroup$– avtomatonCommented Jul 4, 2018 at 9:22
Add a comment
