All the planes I've ever seen taking off (big airliners) first lift the small front wheel from the ground, then rotate and ultimately lift up.
If the small wheel is on the tail instead, in which sequence are the wheels lifted from the ground? Lifting the tail wheel first would pitch the plane down, so the sequence is most likely different.
