14
I want to know the difference between CAN and ARINC, I'm confused about their usage.
For example, the communication between the cockpit and the controllers is done using ARINC protocols. And the data transmitted by probes to the controllers goes over CAN. Why use a different protocol in each case? When is each protocol used?
17
the communication between the cockpit and the controllers is done by using Arinc protocols. And the data transmitted by probes to the controllers is done by CAN.
That depends very much on the aircraft type.
And when can we use each one of them (Arinc and CAN)
When you design your own aircraft you get to choose.
CAN stands for Controller Area Network. CAN is a bus standard designed to allow microcontrollers and devices to communicate with each other in applications without a host computer. It has its origins in the automotive industry.
ARINC stands for Aeronautical Radio, Incorporated. ARINC is an organisation that amongst other activities produces technical standards for avionics and provides services to aircraft operators.
Amongst the ARINC standards there are a number addressing data communications between avionics components. Most widely used is the ARINC 429 standard which describes an avionics data bus. ARINC 429 allows a single transmitter to communicate data to up to 20 receivers over a single bus.
Comparing CAN bus to ARINC 429:
  • Cable
    • CAN: STP or UPT, possible to implement on fiberoptic cable
    • ARINC 429: STP
  • Speed
    • CAN: 1 Mbit/s (high speed) / 125 Kbit/s (low speed)
    • ARINC 429 100Kbit/s (high speed) / 10-14 Kbit/s (low speed)
  • Directionality
    • CAN: bi-directional, connected units can send and receive on the same cable.
    • ARINC 429: uni-directional, a unit either transmits or receives from a cable.
  • Number of units on a single bus
    • CAN: unlimited, although in practice no more than about 32 units will be sharing a bus to avoid data collisions.
    • ARINC 429: one transmitter can serve at most 20 receiving units on a single cable.
Since ARINC 429 has only a single transmitter, timely data arrival is guaranteed, while CAN has to incorporate transmission collision detection & correction which incurs non deterministic time overhead.
On the other hand, ARINC 429 only uses a parity bit for bit level error detection whilst CAN allows for various methods including CRC checks
Some of this data is obtained from an article on CAN bus in avionics magazine.
Newer ARINC busses like 629 or 664 (AFDX) allow for higher speeds and bi-directional communication. These may eventually replace ARINC 429 (but never underestimate how slow progress in aviation is)
  • $\begingroup$ And what about the robustness of ARINC and CAN buses? $\endgroup$
    – Stack Over
    Oct 17, 2015 at 21:11
  • $\begingroup$ Since ARINC 429 has only a single transmitter, timely data arrival is guaranteed, while CAN has to incorporate transmission collision detection & correction which incurs non deterministic time overhead. On the other hand, ARINC 429 only uses a parity bit for bit level error detection whilst CAN allows for various methods including CRC checks. $\endgroup$
    – DeltaLima
    Oct 17, 2015 at 21:24
  • $\begingroup$ It's all about fitting the tool to the job. A Boeing 787 incorporates ARINC 664 for the main network with some subsystems on ARINC 429 and a number of sensors and cockpit controls on CAN (ARINC 825). Almost all the switches on the B787 overhead panel go through a couple CAN busses, eliminating dozens of wire runs. There's also a significant difference in cost. $\endgroup$
    – Gerry
    Oct 17, 2016 at 12:43
  • $\begingroup$ Why do people sometime choose CAN over ARINC629 or vice-verca? It seems to me like they are equivalent $\endgroup$
    – traducerad
    Dec 12, 2018 at 6:03
There are many data communication network standards used in modern aircraft. Each one has its own technical specification and cost implication. You may like to research the following Data Communication systems:
  • ARINC 429 : Single Tx, multiple Rx (20 max) with bandwidth limitations (12.5 Kbps or 100 Kbps). This is both an electrical standard and a protocol standard. Uses 4 byte data words, 19 bits are data.
  • ARINC 629 : Used on the 777, it increased speed over 429 (2 Mbps) and increase the receiver count to 120. It works on half duplex, allowing single interface to send and receive data.
  • ARINC 664 / AFDX : Developed by Airbus, Avionics Full-Duplex Switched Ethernet is used on newer aircraft like A380. Can use commercial off the shelf hardware.
  • CAN bus - also used in A380. Originally developed for the automotive industry
    $\begingroup$ Welcome to aviation.se! Interesting answer -- can you provide links to the various busses you mention as a starting point for the research you've recommended? $\endgroup$
    – Ralph J
    Nov 6, 2016 at 14:53
  • $\begingroup$ You could add MIL-STD-1553 for military aircraft as an avionics bus. $\endgroup$
    – PeterT
    May 19, 2017 at 19:40
