28
I was reading 14 CFR 23.3, which discusses airplane categories. In normal and commuter categories, stalls (except whip stalls) are allowed. The regulation, however does not define "whip stalls." What is meant by this term?
  • $\begingroup$ It happens very quickly. "Whip", then the aircraft stalls. $\endgroup$
    – kevin
    Commented Aug 13, 2015 at 16:54
19
The clearest definition I could find is from an AOPA quiz (of all places):
The airplane is pitched up into a vertical or near-vertical climb. It then pauses, slips downward momentarily (tail first), and then whips into a steep, nose-down attitude.
The tail-first slip backwards seems to be the defining characteristic of a whip stall. Interestingly, Whip Stall and Tumble Awareness is included in the FAA's Powered Parachute and Weight Shift Control PTS, but they aren't defined there either.
