Answer for the question Why are planes using rivets & not welded construction? describes why rivets are preferred for joining aluminium alloy components. But how are carbon-fibre-reinforced plastic components in new aircraft joined?
Ideally, fiber composites are bonded and connected by a scarf joint. The scarf ratio is determined by the ratio of fiber tensile strength and the shear strength of the resin. If your fiber takes 3000 N/mm², the resin transmits 20 N/mm² and the fiber content is 60%, the ratio is 1:90, so a 1 mm thick composite layer would need to be joined over a length of 90 mm. In reality, such a ratio is impractical to achieve, so lap joints are used when accepted by the certification authorities. This is the case for for composite gliders, where you will find both scarf and lap joints.
In the early days of powered composite aircraft, fiber composites were seen with the experience of aluminium in mind, and treated with the same methods. Therefore, the Lear Fan and its contemporaries had to use rivet joints throughout the structure. The idea was that by riveting the airframe could be more easily disassembled for inspection and repairs. Riveting carbon fiber composites is quite problematic: You need to use expensive titanium fasteners because aluminium rivets would quickly corrode when in electrical contact to the electrochemically much nobler carbon fibers. Drilling and countersinking holes cuts the very fibers which you try to connect, so you have to double up on wall thickness what is destroyed by the riveting. But the FAA still insisted on rivets - even stringers on panels were riveted, when bonding would had been the most sensible solution.
Aircraft engineers have an expression for composites that are treated like metal: Black Aluminum. The LearFan was pure Black Aluminum. Many of the engineers in this project ended up with Beech when they produced the Starship, so many of the same techniques were transferred as well. At least, the Starship had a fuselage shell which was laid up on a mandrel and then cut just aft of the cockpit section to get the mandrel out. The splicing of the two fuselage sections was then done by a tapered lap joint; if you want, a practical way of making a not-quite scarf joint.
Today we have a new generation of engineers who slowly accept that the nature of composite structures requires their own methods of treatment. But you will still find riveted joints even in modern composites structures. Old habits are hard to break.
A good reason for riveting is to avoid peeling at the edges of a bonded joint. Engineers with no experience rivet their composites, once they gain some experience they switch to bonding and with lots of experience they add rivets again.
1$\begingroup$ The "Black Aluminum" design/construction using rivets is particularly ironic when you consider the Grumman AA-1 series aircraft, which used a bonded aluminum construction. $\endgroup$– voretaq7Jul 20, 2015 at 15:42
$\begingroup$ This is quite fascinating, especially considering the state of carbon fiber construction in auto racing. Formula 1 car tubs (frame), skin (bodywork), suspension and even gearbox casings are made entirely of carbon fiber, and I doubt you'll find a rivet anywhere. While there are considerable differences in loads between a car and plane, the cars will undergo 2G acceleration as well as 5G braking and cornering forces, and the crash test requirements are even higher. $\endgroup$– FreeManJul 20, 2015 at 17:15
$\begingroup$ @FreeMan … but they can design without the need to please the FAA. Big difference! $\endgroup$ Jul 20, 2015 at 17:56
$\begingroup$ @FreeMan: At that time, there was little experience for a safe judgement, and bureaucrats have to play it safe. Most studies by US companies had indeed used composite panels just like sheet metal. In Germany, gliders had been built the "right" way 20 years before, but Americans like to stick to their own results. As I say, it takes a new generation of engineers to get it right. $\endgroup$ Jul 20, 2015 at 19:28
What about 'Iron Bridge'?
Source: Wikipedia
joints were similar to what a carpenter would use. So using traditional method for a new material, iron. They seem to be doing the same with carbon fiber.
http://www.bbc.co.uk/history/british/victorians/iron_bridge_01.shtml
Time lapse videos of 787 show riveting for the main fuselage.
In composite structures, rivets are used instead of bonding not because of superior performance. Properly designed bonded joint is always stronger than the best riveted or bolted joint. The main reason for using rivets or bolts is that the LONG TIME performance is predictable, while bonded joints may be subject to deterioration due to environmental factors. It is better to have a riveted joint with 50% of maximum theoretical strength (which retains its load capability for the entire service life),than have a superior bonded joint which may deteriorate. Also - as a side issue - bonded joints are practical only up to certain thickness, above which it is better to use bolts.
1$\begingroup$ Bonding is normally done with the same resins that form the composite matrix. So will those matrix materials mysteriously not deteriorate while the joint will rot away? No, rivets in bonded joints are used to avoid peeling. $\endgroup$ Nov 7, 2019 at 5:54
