Can a Boeing 767-200 physically fly at 510 knots at around 400 metres altitude?
If it did manage that speed, how likely would a structure failure be?
Also, if those measurements were achieved, how difficult - relatively - would it be to control?
  • What do you mean by relatively? Also, when the maximum indicated cruise speed of this plane is below 500 knots at cruise altitude, why would you ask such a question? – Victor Juliet Jun 4 '15 at 8:13
  • Thank you Vivian. By 'relatively' I mean how difficult would it be to control at 400m at that speed compared to cruising altitude? Reason for the question is I am looking into something that stated those measurements for that aircraft. – cloudnine Jun 4 '15 at 8:21
  • I hope you understand that this question is ALSO an Engine related question, rather than only being the air-plane related question? – Victor Juliet Jun 4 '15 at 8:22
    Yes, true. Therefore I would extend my question to query whether the engines can produced enough thrust for the increased drag at that altitude etc. Please ignore my ignorance as I am not a pilot or engineer and do not have extensive knowledge - hence my question... – cloudnine Jun 4 '15 at 8:26
  • 7
    It sounds like you're asking if 9/11 was faked. – abelenky Jun 4 '15 at 14:33
The speed is secondary - what determines the physical limits of the Boeing 767 is Mach number and dynamic pressure.
510 kts at 400 m in standard atmospheric conditions equals Mach 0.775. This is well within the limits of the Boeing 767. But at 400 m it produces a dynamic pressure of 40,567 N/m², and that is too much. The maximum dive speed $v_D$ of the 767 is 420 kts.
This only means that flying at 510 kts is illegal, but it is still possible. If the airplane dove down to those 400m from enough altitude, it would entirely be capable to reach this speed, but would slow down once it stops diving.
There are several effects which can cause a catastrophic failure when flying too fast:
  • When the aircraft flies into a gust, the resulting load factor can overstress the structure.
  • When the pilot commands large control inputs, he will also overstress the structure.
  • Flutter might also cause structural damage.
The maximum Mach number of the 767 is 0.91 (0.05 above the maximum cruise Mach number, which is 0.86), and this corresponds to 523 kts in 11,000 m. Thankfully, certification requirements demand a margin of 20% between the maximum speeds and flutter onset speeds, so flutter might be close, but is still tens of miles per hour away when diving to 510 kts. Remember, to experience flutter you need also to excite the motion first. Here is a good discussion of this topic.
In short, flying a Boeing 767 in 400 m at 510 kts is not recommended, but is entirely possible and most likely even safe when done in calm air and by a calm pilot. It only won't last long, because the engines will not produce enough thrust to maintain that speed. Flying this dive requires guts, but no special skills.
  • There’s also the issue of Vmo vs Mmo. The Vmo is 360 KIAS vs 602 KIAS corresponding to an Mmo of 0.91 at those altitudes. Presumably Boeing engineers in a buffer of 20% or so prior to the onset of control surface flutter, so that would allow for a maximum forward speed of 430-440 KIAS prior to the onset of control surface flutter. I don’t think you could get to Mmo at low altitudes like that. – Carlo Felicione Jul 9 at 23:07
  • @CarloFelicione Flutter depends on TAS. v$_{MO}$ is not the limit, that is v$_D$. You need to apply the flutter margin on top of maximum TAS and v$_D$ will give you the maximum dynamic pressure. – Peter Kämpf Jul 10 at 4:46
It would, in all likelihood, be impossible for a large transport category jet to even reach an airspeed of 500 knots at an altitude that low. Drag increases with the square of the airspeed and the transsonic region presents some additional challenges on top of that.
A 767 should have sufficient thrust to accelerate past Vmo at low altitude, but Vmo for a 76- is 360 knots at MSL, a long way away from 500. Even if structural and powerplant failures due to overstress weren't an issue, it's safe to say that a 76- would be drag-limited from reaching anywhere near 500 knots in level flight.
With respect to failure modes, there are structural concerns, skin integrity concerns, powerplant concerns, and Mach tuck, and one or more of these would be encountered long before you had a chance to read 500 on the Airspeed Indicator.
  1. Bending of the airframe - going sufficiently fast will induce the various aerodynamic structures on the aircraft the generate forces and turning moments in excess of what the structure was designed to handle, leading to plastic deformation (and possibly outright failure if the stresses are sufficiently large)
  2. Control surface flutter - this is probably less of a concern in fly-by-wire and hydraulically-actuated control surfaces than for free control surfaces, but at sufficiently high speeds, air particles will strike the control surfaces with sufficient force to displace them and cause them flutter (ailerons are by far the most susceptible to this and the infamous control column "buzz" is caused by this). Sufficiently aggravated flutter has caused control surface separation in several fatal accidents.
  3. Skin integrity - sufficient suction over the top of the wings has been known to cause material, rivets, and inspection panels to separate and compromise the surface. Probably less of a concern for a stressed aluminium metal or composite skin than for a canvas skin.
  4. Mach tuck - the center of pressure moves rearward along the wing chord when the aircraft enters the transsonic regime (the exact speed and characteristics of this shift differ by aircraft) and causes nose-down pitching moments, which may become impossible to overcome. This effect is aggravated in a conventional tailplane arrangement by the generation of standing shockwaves and the subsequent change in airflow separation characteristics.
  5. Powerplant failure - reaching 500 knots would require the powerplant to generate tremendous amounts of thrust, requiring a much greater displacement of air through the compressors (and turbines) and a much hotter burn in the combustion chamber. The resulting engine rotational speeds and temperatures would ruin the engine for further use, if not cause it experience an outright structural failure. There's a pretty infamous case of an Egyptian MiG-25 overflying the Sinai Peninsula at Mach 3+ (the Foxbat was rated for a maximum of 2.8); the engines were toast afterwards.
Though not necessarily a failure mode, something to watch out for in fast-travelling swept-wing aircraft with large wingspans is the possibility the aerodynamic forces might twist the wingtips to the point where aileron functionality is reversed from normal.
Lastly, the control difficulties at such a high speed would stem more from the fact that the control surfaces (especially ailerons) become much more effective at higher speeds (less displacement is necessary in order to generate the forces necessary). Ordinarily, this might lead to an aircraft that is responsive bordering on twitchy and would require very light control inputs, but the story is a bit more complicated in an aircraft like the 76- due to the role played by the envelope protection software and the hydraulic actuation system.
    Keep in mind that the speed of sound decreases with temperature (and thus altitude), This means that at low altitude 510 knots will be a lower Mach number, than the same speed at a high altitude. 510 knots is approximately Mach 0.76 at low altitude – ROIMaison Jun 4 '15 at 13:32
    @ROIMaison - Absolutely, but the critical Mach number of a subsonic wing can be well below the local speed of sound, even for a swept wing aircraft. – habu Jun 4 '15 at 13:41
  • @habu - brilliant answer thank you very much - just what I was looking for (though I will have to go off and research some of your "techy" terminology!) – cloudnine Jun 4 '15 at 14:05
    @habu: I don't count annunciator as envelope protection. By "flight envelope protection" I mean something that will not allow pilots leave the flight envelope at all. And I believe anything like that only exists on A320+ and B777+, but not B767. – Jan Hudec Jun 4 '15 at 14:20
    @habu: But critical Mach number will be the same at any altitude and speed at which Mach tuck will cause problems will be $M_{NE}$ or above. And $M_{MO} = 0.86$, so $M_{NE}$ is more than that (something like 0.92, but I can't find reference now). – Jan Hudec Jun 4 '15 at 14:27
discard
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
