Recently, a small plane operating from a nearby airport suffered an engine failure on takeoff and crashed. One of the hazmat responders dealing with the resulting fuel spill mentioned "a strong smell of Jet A", leading to speculation that the airplane had its tanks filled with the wrong fuel. Would he have been able to distinguish Jet A from 100LL by smell?
3$\begingroup$ Guys who spend all day fueling aircraft know the difference. $\endgroup$ – Tyler Durden Feb 27 '15 at 17:21
If you know what you're looking (sniffing) for, yes.
Avgas 100LL smells like gasoline (a little different than what you pump into your car, but similar).
Jet-A smells like kerosene (not quite "like diesel", but definitely not like gasoline).
If you are familiar with how both smell you can tell them apart by odor, and a significant contamination of Avgas with Jet-A could be detected by smell. (Other tests, like an evaporation test, are more reliable for lower levels of contamination however).
13$\begingroup$ Note that this kind of sniff test is like how if you've worked with solvents you can tell alcohol, acetone, and MEK apart by smell - it may be a useful talent occasionally, but if you make a habit of doing it to impress people at parties or something you'll probably run out of brain cells in a hurry. $\endgroup$ – voretaq7 Feb 26 '15 at 22:09
4$\begingroup$ It would also be a useful talent when filling up your plane, so that the first responders don't have to diagnose that for you. $\endgroup$ – fooot♦ Feb 26 '15 at 22:13
4$\begingroup$ @fooot Presumably the BIG SIGNS on the fuel truck and pump (and the fact that the Jet-A nozzle shouldn't fit into an avgas tank opening) would help there too -- but yet witness the thankfully-infrequent misfueling errors still happening… $\endgroup$ – voretaq7 Feb 26 '15 at 22:28
2$\begingroup$ @voretaq7 - assuming, of course, that the fuel in the tank matches the sign -- my dad (and a few other people) once got an engine rebuilt for "free" when a gas station pumped diesel into his tank instead of gasoline, apparently the delivery truck put the diesel in the wrong tank. The car left an impressive smoke trail before it died. I don't know if this happens much (if at all) at airports, but it does happen at gas stations from time to time $\endgroup$ – Johnny Feb 27 '15 at 4:06
3$\begingroup$ @JanHudec If it's pure Avgas or pure Jet-A yes: 100LL will be a light blue color, and Jet-A is undyed (usually described as "straw yellow"). If the two are mixed together though you can have a mix that would destroy a piston engine but still look "blue" in the fuel sample cup -- that's where the telltale odor of Jet-A (or an evaporation check) will catch the problem for you. $\endgroup$ – voretaq7 Feb 27 '15 at 7:37
Sounds like there was no fire at the accident site so that's good.
It is possible that a mixture of 100LL and JetA (say 3/4 tank of 100LL topped off with JetA) could have passed the smell test and color test during sumping but still have caused the accident.
Possibly the Avgas evaporated quickly at the scene leaving only the jet fuel lingering for the hazmat responder to smell. So even a partial mixture could have done it.
However, if you pulled up to any arbitrary FBO or self service rig to fuel your aircraft, you would not be able to get the JetA nozzle to fit in your tank. The following is an excerpt from this wiki page: http://en.wikipedia.org/wiki/Aviation_fuel
Because of the danger of confusing the fuel types, precautions are taken to distinguish between avgas and jet fuel beyond clearly marking all containers, vehicles, and piping. The aperture on fuel tanks of aircraft requiring avgas cannot be greater than 60 millimetres in diameter. Avgas is often dyed and is dispensed from nozzles with a diameter of 40 mm (49 mm in the USA).[7] [8]
Jet fuel is clear to straw-colored, and is dispensed from a special nozzle called a J spout that has a rectangular opening larger than 60 mm diagonally, so as not to fit into avgas ports. However, some jet and turbine aircraft, such as some models of the Astar helicopter, have a fueling port too small for the J spout, and thus require a smaller nozzle.
Here is a graphic showing the two spout sizes:
Simply put, a JetA fueling nozzle will not fit in the aircraft tank's filler neck. So if there was a fueling mishap, it almost needed to be done by the operator with a homebuilt self fueling rig in his hangar.
Side note: In the late 80s or early 90s when I owned an FBO with a maintenance shop, the Chevron facility in Richmond CA had a refinery valve mishap and filled several tanker trucks with avgas while JetA was leaking into the delivery apparatus. There were many dozens of piston aircraft fueled by the time they discovered and remedied it. The FAA issued an AD against all aircraft that got some of this fuel and Chevron bought each owner an overhaul.
1$\begingroup$ I once read of an accident caused by the fuel truck or tank itself being filled with the wrong fuel. There was another accident caused by the fuel trucks not having the proper nozzles. If I can locate the accidents, I will post them. Either way, there was a failure or break down in accepted safety procedures. $\endgroup$ – Dean F. Sep 5 '20 at 16:11
