I'm currently doing a PPL in the UK and have only flown around 5 hours with an instructor. Training aircraft is a Cessna 150.
One thing I'm finding confusing is when carb heat should be set to COLD. But moreover, when would you switch from FULL HOT back to FULL COLD?
The book I'm learning from is Pooley's "Flying Training" Volume 1. This book states in Exercise 4g
Carburettor ice can occur at outside temperatures of +25C or more ... Noticeable effects include a drop in rpm, rough running, possible engine stoppage.
The suggestion is you would apply FULL HOT carburettor heat in such situations, e.g. during rough running of the engine. This makes sense.
It doesn't, however, say when you would go back to FULL COLD. My assumption here is just whenever the condition has been recovered. For instance if the engine is rough running you could apply FULL HOT carb heat, wait for the engine to run smoothly again, and then go back to FULL COLD?
The only scenario I've come across where you'd explicitly use COLD is taxiing. The reason given by the book is
the hot air for the carb heat is supplied from around the engine exhaust and is unfiltered ... For this reason it us usual to taxi with the carb heat control in the FULL COLD position to avoid introducing dust and grit into the engine.
The book also states in the Airwork section for Exercise 4g
Using Carb heat as a precaution. When reducing power to IDLE: Set carb heat to FULL HOT. Throttle closed. When about to increase power: Set carb heat to FULL COLD (if hot air to carburettor no longer required).
Sentences such as "if hot air to carburettor no longer required" seem ambigious. It doesn't tell me under what scenarios that would be acceptable. Many sections of the book will say "apply FULL HOT carb heat" but never state when you would change back to COLD, i.e. you'd carry on the entire flight with FULL HOT carb heat, which I know even from a common sense perspective cannot be true.
Some searches I've done on this subject such as
- https://www.reddit.com/r/flying/comments/1vg9xl/when_do_you_use_carb_heat/
- Should I have carb heat on for landing in a C152?
make it seem that this is a debatable subject, which I find astonishing given how important this control supposedly is.
Any clarification would be appreciated. Please take into consideration I am relatively new to flying and trying to learn from those with relevant experience.
