According to FAA Order 7110.65AA, 5−7−1.b. Do not assign speed adjustment to aircraft: 4. Inside the final approach fix on final or a point 5 miles from the runway, whichever is closer to the runway.
However, according to ICAO Doc 4444, 4.6.3.6 Only minor speed adjustments not exceeding plus/minus 40 km/h (20 kt) IAS should be used for aircraft on intermediate and final approach.
I thought ATC can't assign speed adjustment if the aircraft is on final approach segment.(after having passed FAF) However, according to ICAO Doc 4444, is it possible? In real situation, what procedure does ATC usually apply?
