I've had this discussion with my FI: Are speeds such as Vx and Vy referring to IAS at all times or TAS that needs to be compensated for?
Here's an example. Let's assume the following:
- Vy of my single piston engine, fixed prop aircraft is specified at 70 kts
- I'm taking off from 0 ft MSL, climbing to 5000 feet pressure altitude
- it's +15° celsius outside temperature with a QNH of 29.92 Hg / 1013 hPa (all ICAO standard)
Which of these two scenarios would actually get me to my target altitude faster?
- I'm constantly pitching for 70 kts IAS under full power
- I'm constantly pitching for 70 kts TAS under full power, i.e.:
- 70.0 kts IAS @ 0 ft
- 68.6 kts IAS @ 1000 ft (70 / 1.02)
- 67.3 kts IAS @ 2000 ft (70 / 1.04)
- 66.0 kts IAS @ 3000 ft (70 / 1.06)
- 64.8 kts IAS @ 4000 ft (70 / 1.08)
- 63.6 kts IAS @ 5000 ft (70 / 1.10)
I was assuming an appoximate increase of 2% per 1000 feet in TAS compared to IAS. My FI says that scenario two would actually yield in an optimal climb, but I'm uncertain as to how the reduced air density would affect lift and therefore the optimal speed to maintain.
