If an aircraft like a Cessna 172 is dropped from a helicopter, what absolute minimum altitude above the ground will be required to safely land the aircraft?
CONDITIONS:
- Weather: Perfect conditions, 0 knot wind.
- Ground: 0f ASL.
- Gross weight: Max gross weight.
- Engine: off.
- Speed: 0 knot(standstill drop).
- Pitch Attitude: 0 degrees(as in the picture).
- The helicopter is just an "abstraction"(there is no downwash exerted on the airplane)
PS: if you can simulate this on XPlane your results will also be welcomed(I don't have it).
Also, if you want to answer from a slightly different scenario like a stall, though not the same as the scenario described above, your answer will also be welcomed.
NOTE: The question is purely about physics / aerodynamics. Not planning on doing this in real life.
