The fuel-injected engine has six cylinders, so it's not a "per-cylinder" thing nor is it related to a carburetor.
P.S. That screen is the entirety of the air filter. Apparently it's meant to keep out small birds, and not much else.
Sign up to join this communityThe fuel-injected engine has six cylinders, so it's not a "per-cylinder" thing nor is it related to a carburetor.
Those are the impact tubes for the fuel metering for the RSA-type fuel injection system:
Above is the face of the fuel servo. If you had more light you would have also seen the throttle valve as shown above. When the throttle opens, air rushes in, and the higher pressure in the impact tubes would deliver more fuel. See schematic and description below:
... As a result, the diaphragm moves to the left, opening the ball valve. Contributing to this force is the impact pressure that is picked up by the impact tubes. [Figure 2-32] This pressure differential is referred to as the "air metering force." This force is accomplished by channeling the impact and venturi suction pressures to opposite sides of a diaphragm.
Source: FAA-H-8083-32A. Aviation Maintenance Technician Handbook-Powerplant Volume 1.
