Do small airports or regional airports with just a couple of flights per day, maybe even from different airlines all have on-site aircraft maintenance staff? It hardly seems economical to have certified on call mechanics at most small airport? Are there regulations requiring such?
If there are not any, what happens if a hard landing is performed? From my knowledge an inspection by a mechanic is then required.
    $\begingroup$ Well, the pilots known to be prone to hard landings, are sent to the airports where the maintenance staff are-- $\endgroup$ Apr 12, 2021 at 20:35
  • $\begingroup$ you mention "airlines", so I think you are limiting it to airlines, and not GA, if yes, please make it more explicit, thanks $\endgroup$
    – user14897
    Apr 12, 2021 at 22:48
    $\begingroup$ Since you're asking about regulations, there is a related topic, though it's about firefighting. You'll see the linked regs do not mention maintenance as part of an airport's certification: Are there regulations that limit the airports an air carrier can visit based on rescue equipment? $\endgroup$
    – user14897
    Apr 13, 2021 at 0:34
  • $\begingroup$ Small airports wouldn't have airline flights landing at them. $\endgroup$
    – jamesqf
    Apr 13, 2021 at 18:20
  • $\begingroup$ @jamesqf: How small are you talking? Tiny untowered airports get scheduled air carrier flights too; a quick look at some airline websites shows (just for example!) BTM, CDC, EAR, DIK, DRO, MTJ. From my brief survey it does look like all of those are Class-E-to-surface and do have airframe/powerplant service according to AirNav. $\endgroup$
    – randomhead
    Apr 13, 2021 at 22:44
4 Answers 4
For scheduled commercial aircraft you will generally find:
If enough aircraft are coming and going from a particular airport, the airline may keep a line maintenance operation running there that can handle short-term maintenance and troubleshooting, or special inspection operations.
If not, and the airport has a AMO (approved maintenance organization) on site, the airline may contract with the AMO for line maintenance services, troubleshooting or special inspections.
If that's not the case, the airline will simply fly mechanics to the airport when airplanes are AOG. This is typical when airplanes have problems that prevent dispatch at small remote airports.
So if an airplane needs a hard landing inspection at a remote "outstation", it'll be done by local contract staff if an AMO qualified to do the inspection is there, or barring that, airline staff flown out to the site.
  • $\begingroup$ the airline may also regularly have a line engineer and mechanic on board with a flyaway kit to such an airport $\endgroup$
    – user14897
    Apr 13, 2021 at 0:28
  • $\begingroup$ They generally all carry flyaway kits in the cargo area, which is mostly a box of the MMEL related items like blanking plates. I don't think it's done much in NA or Europe, but yes flying with a mech on board on every trip was done by some Regional operators in China and other places like that. $\endgroup$
    Apr 13, 2021 at 12:41
  • $\begingroup$ Don’t airlines also have agreements to work on each others’ planes? Might technically fall under AMO, but IMHO worth adding. $\endgroup$
    – StephenS
    Apr 14, 2021 at 16:25
In my experience you can often find an A&P at a lot of (but not all) airports even really small ones like KDYL where I learned to fly. However these mechanics may not have the experience or know how to work on all aircraft all the time but can likely handle most straight forward issues that could arise for the aircraft that land at the field. These mechanics may not work for the charter or airline operations based at the airport or elsewhere but are often more than capable of working on their aircraft provided the airline/charter operation permits it.
Keep in mind that at a great deal of airport there are at least a few aircraft based there (commercial or not) and all aircraft need at least an annual inspect so a mechanic is often never far off.
If local maintenance is not an option its not uncommon for mechanics to be dispatched to the field for an onsite repair.
As others have said, airlines may have line-maintenance staff on-site, either organic or contracted through an AMO of their choice. On the GA/non-airline side of things, you can almost always find an A&P or an FBO. Most airports that a regional airline would fly to, and many that receive NO scheduled airline service, have at least one FBO. Take Martin State Airport (KMTN), a Class D general aviation/reliever airport. The runway's about 7,000 feet long, so it receives quite a bit of bizjet traffic and general aviation. There are 232 aircraft based there, so there's definitely maintenance, between the FBO and the A-10 squadron based on the field. Don't expect to land your J3 Cub and get maintenance from the A-10 guys, but they count as maintenance on-site. According to AirNav, you'll find minor airframe and powerplant service, but no oxygen of any kind. It's a rare airport that has absolutely NO maintenance personnel on-site, even if they're private A&Ps not working for the airport, but I'm sure they exist. Small bush strips (debatable whether or not you can truly call that an airport) might not- the one that comes to mind is Trent Palmer's runway outside his house- he's not an A&P, so no MX on-site. However, it's certainly more common that there's maintenance on the field than not.
Airports usually do not hire maintenance staff for other than maintaining the airport facilities. Companies (Airlines, FBOs) that operate there will usually have a base and have the required staff on site. If you land at an airfield where there is an established FBO and you ding your plane, you could ask them to repair it, if it falls within their operating certification. Otherwise you will have to solicit the services of an organisation based elsewhere.
