As the FAA mentions, the ADS-B messages like Identification, Position and Velocity are transmitted randomly uniquely between $ 04 \pm 02 $ sec.
How does the transmitter define that randomization? Is it standard or fixed or else who decides that?
  • $\begingroup$ Presumably it uses a form of a Random Number Generator, like any other computer would use to generate random numbers. I'm also not sure that "standard/fixed randomization" is a concept that exists. $\endgroup$
    – zymhan
    Commented Feb 7, 2020 at 13:50
  • $\begingroup$ The random delay is introduced by a function called General Formatter / Manager, it is uniform and its unit of time must be less than 15 ms. Non cryptographic uniform random sequences are usually obtained using Linear-feedback shift registers but I don't know what is used for ADS-B Out.. $\endgroup$
    – mins
    Commented Jun 22, 2021 at 23:05
The standard DO-260B dictates that ADS-B devices must generate uniformly distributed random numbers. They do that by using a PNRG algorithm.
Note sure where the number $ 04 \pm 02 $ comes from, indeed the broadcast randomization specifications are the following (source§7.3.2):
Message Condition Interval
Airborne position - $ 0.5 \pm 0.1 $ sec
Airborne velocity - $ 0.5 \pm 0.1 $ sec
Surface position Moving $ 0.5 \pm 0.1 $ sec
Surface position Stationary on ground $ 5 \pm 0.2 $ sec
Aircraft idententification Moving or Airbone $ 5 \pm 0.2 $ sec
Aircraft idententification Stationary on ground $ 10 \pm 0.2 $ sec
TSS Airbone and valid state $ 1.25 \pm 0.05 $ sec
Aircraft Operational Status Various conditions Complex (see source)
