I know that commercial aircraft continuously freshen the cabin air when aloft by compressing and cooling the air.
Is that true when the aircraft is on the ground, at the gate loading or taxiing?
Sign up to join this communityI know that commercial aircraft continuously freshen the cabin air when aloft by compressing and cooling the air.
The aircraft when on ground and starts to board passengers is switched to ground power or auxiliary power which runs the air conditioning system. When disconnected, the engines supplies the power and bleed air for the cabin pressurization.
"On the ground, the airplane is unpressurized and the outflow valve is wide open. During preflight, the pilot sets the cruise altitude on a cabin pressure controller. As soon as the weight is off the main wheels at takeoff, the outflow valve begins to close and the cabin starts to pressurize."
Source - https://www.airspacemag.com/flight-today/how-things-work-cabin-pressure-2870604/
If the engines are off, ie. durring boarding or while waiting at the gate, the APU can supply the necessary bleed air and electricity to operate the PACKs that supply air conditioning to the cabin. It is up to the crew to decide wether to use it or not, depending on ambient conditions: on a nice 21deg sunny day vs. a cold and snowing -4 deg.
Now that APU running in the tail, for each aircraft parked on the stand, sometimes for dozens of minutes can add up to quite a lot of noise on th apron, so most airports will have regulations as to how much time you can use the APU. Some will even cordially (for a fee) provide air conditioning through a specially mounted tube that connectes to the airplane systems, allowing cool air to enter the cabin while the APU is switched off
