There are various type of data bus in aviation, the two most common in the '90 were ARINC 429 for civil aviation and Mil 1553 for military applications. They are not very different one for the other, the Mil is a little more complex.
My question is: why use two different data bus? The physical cable is the same (as far as I know, you can correct me if I am wrong) but the protocol is different. I think that what a data bus must do is the same in civil and military avionics, am I wrong?
  • $\begingroup$ My understanding (from integrating electronics into aircraft platforms) is that 1553 is used in civilian avionics devices. $\endgroup$
    – mongo
    Jul 11, 2017 at 17:44
    $\begingroup$ The avionics I have worked (all civilian) with use ARINC 429 because that is what is predominately used on the aircraft. Hopefully someone might have some historical insight into the original aircraft that used Mil 1553 vs ARINC 429. I've also seen RS-232/422/485 used as the electrical standard $\endgroup$ Jul 11, 2017 at 18:14
  • $\begingroup$ @mongo I concur, ARINC-429 is for civilian use having worked with all major air-framers and major airlines around the world. $\endgroup$
    – Snoop
    Oct 6, 2017 at 14:05
  • $\begingroup$ The two are actually quite different. ARINC429 is 32 bit standard while 1553 is 20 bit, encoding the 1 or 0 is bipolar return to zero vs Manchester II bi-phase, simplex vs time division multiplexing, 1553 needs a bus controller, bit rates are wildly different... could go on... $\endgroup$
    – Craig
    Aug 3, 2021 at 6:34
16
There is actually quite a lot of difference between ARINC-429 and MIL-STD-1553. They are different because they were developed by two different groups with different needs.
Both started in the 1970's. Before then there was almost no digital data of any kind on a an aircraft. It was almost all analog or discrete. The biggest issue was noise and interference of the signals. The introduction of microprocessors in the early 70's opened up the option for reasonably priced digital bus technology.
The MIL-STD-1553 bus was a major component of the F-16. Like most military programs, this was a push for maximum performance. ARINC-429 came out of the Boeing 757/767 development effort. Civilian aircraft certification doesn't like a lot of risk and the simpler bus architecture made it easier to design, analyze, and certify.
Since then there have been a number of new buses introduced into aviation. Some have lasted longer than others. B777 introduced ARINC-629 and Fibrechannel. B787 uses ARINC 664 for the main buses with a large mix of ARINC-429 and ARINC-825 (CAN bus) as well. There are a number of data concentrators/converters on the aircraft to get data where it needs to go.
The primary reason for moving away from ARINC-429 is that it is a single transmitter/multiple receiver architecture. This results in a large amount of physical wire. That adds weight and requires maintenance. A bus such as ARINC-664, which is based on Ethernet, can significantly reduce wire. The down side is that it costs a lot more and isn't very efficient when all you need is a small, low rate connection to an odd corner of the aircraft. So you end up with a mix of buses.
And B787 opted for fiber optic cable for the ARINC-664 network to reduce interference from high-intensity radio frequency (HIRF) and lightning.
MIL-STD-1553 is a powerful bus, but it's not as good a fit as many of the newer buses available in the commercial market. The military keeps using it because they have a huge installed base of equipment, it's flexible enough to support their newer functional needs, and commonality reduces their logistics costs.
ARINC-429 sticks around because it's cheap and it has its own large installed base as well.
