I've seen 2 safety videos of A330s - one with Nepal Airlines and another of (now defunct) Jet Airways.
Both of them say that doors 3 left and 3 right cannot be used in a water evacuation.
Why is it so?
Why is it so?
It depends on the type of door that is installed at position 3L and 3R. Airbus offers the A330 with a type 1 door, which is a smaller emergency exit door, and optionally with a full type A door. Only the type A door emergency escape slide can be used as a raft, therefore evacuation on water should not be performed through 3L and 3R when only a type 1 door is installed:
(Airbus Aircraft Characteristics - A330)
That is why some operators like Emirates (left) instruct passengers not to use doors 3L and 3R on water, but others like Air Transat (right) allow this:
(image sources: Emirates, Air Transat)
If you compare pictures of the Emirates and Air Transat A330s, you can see the larger type A door on the Air Transat:
