14 CFR 91.225(d):
After January 1, 2020, except as prohibited in paragraph (i)(2) of this section or unless otherwise authorized by ATC, no person may operate an aircraft in the following airspace unless the aircraft has equipment installed that meets the requirements in paragraph (b) of this section:
- (2) Except as provided for in paragraph (e) of this section, within 30 nautical miles of an airport listed in appendix D, section 1 to this part from the surface upward to 10,000 feet MSL;
Breaking that down: You may not operate within 30 miles of a "Mode C veil" airport unless you have a working ADS-B Out setup, or unless your aircraft was originally certificated without an engine-driven electrical setup (and has not subsequently been so certificated). The "upward to 10,000 feet" is not a loophole because once you reach that altitude paragraph (d)(4) takes effect.
But there are two general "outs" that you have available to you: the prohibitions in paragraph (i)(2) and an ATC authorization.
Paragraph (i) incorporates by reference the technical standards for ADS-B Out. I'm not sure how an operation could be prohibited by that paragraph... maybe they're saying that if your equipment is out-of-standards then you aren't allowed to use it? It isn't clear.
But the ATC authorization is easier to understand: ATC may approve a deviation from any of the ADS-B Out requirements. The FAA has set up the ADS-B Deviation Authorization Preflight Tool (ADAPT) "to manage these authorization requests." In order to be considered for a deviation, you need to have a working Mode C transponder and you need to submit the request between 24 hours and 1 hour before your flight.
The ADAPT page does have a note saying that the FAA will not issue in-flight deviations nor will ATC facilities accept requests by telephone. If this is approved FAA policy then I have not been informed of it. FAA JO 7110.65 does include a paragraph instructing controllers how to handle requests to deviate from transponder/Mode C requirements between 10,000' and 18,000' (91.215), but I do not believe there is any guidance on dealing with ADS-B deviation requests (91.225) in either JO 7110.65 or JO 7210.3. So you could make your deviation request by telephone (make sure to call a recorded line!) or over the frequency to a controller, and they may or may not approve it. Using the ADAPT would probably provide a better paper trail for everyone involved, however.
