I've heard claims that flying a UAV using a Virtual Reality headset (for example, the oculus rift) is illegal per FAA regulations.
Is this true? I cannot find any definitive answer either way.
According to Model Aircraft Operations one of the requirements for flying a model aircraft is:
  • Keep the aircraft within visual line of sight at all times
If you are wearing a VR headset, then your visual line of sight stops at the headset screen.
Note that the above linked page lists the "visual line of sight" as a safety guideline. However, according to Section 336, an aircraft is not considered a "model aircraft" unless it is:
(2) flown within visual line of sight of the person operating the aircraft
None of the above restricts you from flying with a friend where one of you is wearing the VR headset and the other is piloting the aircraft.
