After listening to this funny exchange Kennedy ATC audio on youtube, about how ATC didn't knew Norwegian Airlines callsign was "RedNose", it occurred to me, why not have the option so that every aircraft can use a simple naming structure of just 2 words. Some times I find it painful to listen so many long call signs specially in congested areas.
This is my suggestion:
- You would go to the ICAO website to pick the 2 word combination you want tied to your tail number.(the system will tell you if your combination is available/not taken)
- ICAO would create a list of approved English words from which one could pick the desired 2 words combination.(the list could be updated annually by ICAO)
- Those words would be picked by ICAO based on criterias like simplicity, popular/global recognition, not conflicting(ie words like "airplane", "airspeed", "altitude" shouldn't be allowed), etc.
- Airlines could also use this by suffixing one word after their company name(ie. AmericanHappiness, UnitedDreamer, DeltaJupiter, DeltaHumble, etc)
- Yes, there are enough English words so that we only have to use 2 words combination for the total aircraft population(For the current system the English alphabet only has 26 letters and 9 numbers in a combination of 6 positions for the tail naming. In contrast, the number of usable words for the proposed system could be up ti 100k with 2 positions)
- This would not be a requirement, only a option available to every aircraft owner if they choose to, they could still use their tail number call sign if they want.
I mean seriously guys, don't tell me you want to be called NovemberFourTwoSixAlphaCharlie(N426AC) when instead you could be called:
FreedomLover
SweetMango
BigLion
WhiteIndian
CuteFace
I think this would be easier to remember, simpler, faster/shorter readbacks, and more distinguishable.
PS: I'm not proposing to change the tail number naming structure, just the call sign, the same way comercial airlines can have a different call sign than the tail number.
