In a recent conversation about the Diamond DA62 I was speaking with someone who thought the aircraft was pressurized. I was shocked considering the door design. Shocked to the point of disbelief. A quick Google search referencing the following page seemed to prove that it was indeed pressurized.
Yes, the DA62 is pressurized. The aircraft features a baseline cabin pressure altitude of up to 8,000 ft at the specified maximum operating altitude (28,000 ft). This helps to reduce fatigue during long flights, and make the experience of flying more comfortable for passengers.
https://www.newzealandrabbitclub.net/is-the-da62-pressurized/
Hard to believe! I tried and found no reference to it's differential pressure limits or operation of its pressurization system. There are videos of pilots wearing cannulas above 10,000 feet.
So, is the Diamond DA62 pressurized or not?
  • 10
    $\begingroup$ Diamond's own website says the DA62's service ceiling is 20,000 ft, which contradicts the New Zealand Rabbit Breeder website you cited... and that makes me somewhat suspicious that the New Zealand Rabbit Club is not the foremost authority on the details of the DA62... $\endgroup$
    – randomhead
    Jul 9 at 21:10
  • 23
    $\begingroup$ It feels to me like the "New Zealand Rabbit Club" page about... aircraft.... is written by AI for the sole purpose of generating clicks in response to Google searches $\endgroup$
    – Ben
    Jul 9 at 22:37
    $\begingroup$ What does the New Zealand Rabbit Club have to do with airplanes? $\endgroup$
    – Someone
    Jul 9 at 23:16
  • 13
    $\begingroup$ I'm 99% sure I know the original source of that quote now. Me: "Is the DA62 pressurized?" ChatGPT: "Yes, the Diamond DA62 is a pressurized aircraft. It is a twin-engine light aircraft manufactured by Diamond Aircraft Industries. The pressurization system allows the cabin to be maintained at a higher atmospheric pressure than the outside environment, providing a comfortable and controlled environment for the occupants during flight. The pressurization system helps to reduce the effects of altitude, such as hypoxia, and allows for more efficient and comfortable high-altitude operations." $\endgroup$
    – Someone
    Jul 9 at 23:18
    $\begingroup$ As a Kiwi, I can confirm that website doesn't even know rabbits, let alone airplanes. Heck - even Wikipedia knows that the "New Zealand" rabbit breed is from California. It is clearly a pile of scripted twaddle that doesn't belong on the web. "do your research" means more than one source, ideally independent sources. $\endgroup$
    – Criggie
    Jul 10 at 11:39
16
No, neither the DA 62 nor the DA-50RG are pressurized, though they do have an integral supplemental oxygen systems onboard. I have no idea where the New Zealand Rabbit Club(?) came up with that, but they are misinformed.
What appears to be going on is that they are confusing cabin pressurization with critical altitude on the turbos. The DA 62 does have a critical altitude somewhere in the neighborhood of 12 to 14,000 feet MSL and a maximum operating pressure altitude of 20,000 ft. This is very different than a cabin altitude. The video also features a Piper PA-46 Meridian, which is, in fact, pressurized, so I don’t know if they are confusing the two aircraft. In fact, the quoted 8000 foot cabin altitude at FL280 sounds about right for a non-RVSM certificated Meridian.
    $\begingroup$ Me: "Is the DA62 pressurized?" ChatGPT: "Yes, the Diamond DA62 is a pressurized aircraft. It is a twin-engine light aircraft manufactured by Diamond Aircraft Industries. The pressurization system allows the cabin to be maintained at a higher atmospheric pressure than the outside environment, providing a comfortable and controlled environment for the occupants during flight. The pressurization system helps to reduce the effects of altitude, such as hypoxia, and allows for more efficient and comfortable high-altitude operations." $\endgroup$
    – Someone
    Jul 9 at 23:20
  • 11
    $\begingroup$ AI just ain’t that intelligent, is it? $\endgroup$ Jul 10 at 1:47
    $\begingroup$ Having experience on the DA-42, I would also have concerns on how the 62 would be able to pressurize properly. The doors on it are pretty large and don't really have a good edge seal or a good locking mechanism for pressurization. There is also the little windows on both pilot side windows that pop open pretty easily already with no pressurization. $\endgroup$ Jul 10 at 17:02
  • $\begingroup$ @CarloFelicione It's a lot of A, but not much I. $\endgroup$
    – Mast
    Jul 11 at 19:29
Here is a copy of the Airplane Flight Manual for the Diamond DA62 . I've never seen one (other than an image), but there is no mention of a pressurization system in the Flight Manual.
Image from the Diamond Aircraft website :
