The A220-100 and -300 variants have relevant specs of (respectively)
- fuel capacities of 21,805L and 21,508L
- MTOW of 63T and 71T
- Range of 3450 nmi and 3600 nmi
How is the bigger, heavier variant specified to go further on less fuel?
Sign up to join this communityThe A220-100 and -300 variants have relevant specs of (respectively)
I assume the numbers you found are from the Wikipedia article. If you look closely at the specifications table, you'll see that the numbers are from two different publications:
The Airbus Family Figures Booklet (2019), which lists the following data:
A220-100 | A220-300 | |
MTOW | 63.1 t | 69.9 t |
Fuel Capacity | 21 805 l | 21 508 l |
Range | 3400 NM | 3350 NM |
An article (2021) about improved MTOW and range for the A220-300:
It will take the MTOW of the -300, the larger of the A220 variants, to 70.9t from the current 69.9t and will provide some 200nm additional range.
So the range of the A220-300 was originally lower than the -100, but was improved due to the higher MTOW. It still has a lower fuel capacity, but range (with payload) is not limited by fuel capacity. It is limited by MTOW as you can see in the payload/range plots:
As you can see from these plots, the maximum range (ferry range) of the A220-100 is higher than the -300, but the -300 can fly further with 140 passengers than the -100 with 120 passengers due to its higher MTOW, therefore giving it a higher typical range.
