Autogyro and helicopter blades are more or less flexible, and when not stiffened by centrifugal force they droop noticeably. A extreme case would be that of fabric blades. They have been used at least once, as propeller blades in the airship ‘Parseval’. Could fabric blades work as rotor blades of an autogyro?
From page 75 of book 'Der Zeppelin' ISBN 9783613034099
  • $\begingroup$ Do you mean a blade with no spar that just flops down like an old sock when not spinning? $\endgroup$
    Jun 12, 2023 at 12:23
  • $\begingroup$ Yes... Like the non-spinning blades in the left picture... $\endgroup$
    – xxavier
    Jun 12, 2023 at 12:51
  • $\begingroup$ Many (if not all) "first flights" helicopter and De la Cierva's autogyros had for sure fabric-covered blades. $\endgroup$
    – sophit
    Jun 12, 2023 at 13:34
  • $\begingroup$ @sophit. Yes, but one thing is a rigid structure with a fabric covering (like many wings, fixed or rotating), and another very different is a completely 'floppy' blade, stiffened only by centrifugal force... $\endgroup$
    – xxavier
    Jun 12, 2023 at 13:48
    $\begingroup$ More than the missing pitch control, the missing torsional stiffness would be a paramount problem. Due to the aerodynamic environment typical of rotating wings, the blade would be torqued with different intensity along its span and in a oscillating manner. With no proper structure supporting this movement, the blade would flap in torsion just like a flag. $\endgroup$
    – sophit
    Jun 12, 2023 at 20:14
For thrust to pull on the hub, a propeller blade must be able to transfer shear loads from the circumference to the center. Add a bending moment when the distance between the circumference and the hub becomes nonzero. This requires a stiff propeller.
With flexible blades thrust can be achieved when the blades form a cone from the lift force pulling them forward. This will be added to the tension created by the centrifugal force on the blades. From the right picture it seems that no such lift was achieved when the picture was taken.
However, the Parseval dirigibles could achieve speeds above 40 km/h, so the caption "… UND IN FAHRT" (… and in motion) is not quite correct. The complex hub arrangement actually allowed to change blade pitch and even to reverse pitch in flight.
Austrian military dirigible M1
Austrian military dirigible M1 (picture source), a Parseval-type dirigible built in 1909.
Now to your question:
Maybe, when spun up before take-off. A typical autogiro does not need to power its rotor directly because it is set in motion by the airflow. Later Cierva autogiros did power the rotor in order to shorten their takeoff distance. Once in flight, all power is used to spin the propeller because driving the rotor would create undesirable torque which needs to be counteracted either by a second rotor spinning in opposite direction or by a tail rotor like in Sikorsky-type helicopters.
It is important to keep the blades at a positive angle of attack so they will constantly produce enough lift to keep the autogiro afloat. While it seems that changing the attachment points of the two ropes which formed the leading and trailing edges of the propeller blades was enough for the Parseval propeller, the much higher aspect ratio of a typical autogiro blade will most likely restrict lift production to the blade section close to the root. Since a flat plate is indifferent to pitch changes, the pitch angle of such a blade would be only controlled by the tension in the ropes from the centrifugal force. This could work but I would rather use a stiff blade to make sure that their angle of attack is well controlled.
Also, a good airfoil will increase the range of possible angles of attack with good efficiency which is especially helpful for helicopters. Using a flat plate airfoil will definitely cost performance.
