This research paper shows that for a given aspect ratio and wing area, compared to a monoplane a biplane produced a better L/D. So, wouldn't it make more sense to manufacture biplanes for subsonic flight instead when size and wingspan restrictions are involved?
1$\begingroup$ Without reading the 100+ pages, could you point to the section where it's claimed that biplanes produce better L/D than monoplanes? That claim runs contrary to what I've always understood. There's much more interface drag for a biplane, and the wings also interfere with each other. Both lead to more D for the same amount of L. $\endgroup$– Kenn SebestaJun 10 at 12:16
$\begingroup$ @KennSebesta, most of the paper just consists of appendices and the whole thing is just a wind tunnel test experiment, if you want the cliff notes for the lower L/D, check out the conclusion section. $\endgroup$– Dwight SchruteJun 10 at 13:41
2$\begingroup$ Would it be beneficial for the Boeing 777x to have a biplane wing design? and Why are there no longer any biplanes? $\endgroup$– minsJun 10 at 15:58
$\begingroup$ So, is the research paper wrong when it claims that biplanes have a lower L/D for a given wing area and aspect ratio? $\endgroup$– Dwight SchruteJun 10 at 18:56
3$\begingroup$ I don't think anyone here is going to read a random paper to refute it. It's entirely possible that the linked masters thesis highlights a very specific point where biplanes could conceivably do better. I think if you want an answer here, you need to rephrase the question with the specific point in question so we can address it. $\endgroup$– Kenn SebestaJun 11 at 12:09
Show 2 more comments
