I will be doing a multi-engine course in a 2006 Diamond DA-42 soon and I'm curious if this is true for the aircraft and under what circumstances the propeller would auto feather. For example, if the engine is starved of fuel or fails for whatever reason, would it auto feather? How about if the governor fails, and if so, under what types of failure with respect to that system would it auto feather? Or maybe the ECU has a fault and the system doesn't automatically switch to ECU B for that engine without pilot input. The POH doesn't specify if this aircraft will do this or not for any sort of scenario.
I am aware that turning the engine master off will cause the governor valve to open and the oil to flow out, resulting in the pitch becoming coarser/higher and feathering, during which time the accumulator will close to maintain pressure to unfeather when it's needed (engine master turning back on). I am also aware that if the RPM is below 1300, then feathering isn't possible due to the coarse pitch stops.
