I'm simplifying some blade element theory problems by assuming that the propellers are perpendicular to the ground and their motion is constrained to being purely vertical (without forward velocity).
Im having some trouble calculating gamma, which is the arctan of the coefficient of drag divided by the coefficient of lift. This is related to the lift-to-drag ratio, as it is the arctan of its inverse. This gave me the idea to use lift-to-drag equations (like total drag = induced + zero lift) for finding gamma
However, lift-to-drag ratios are typically used for things like aircraft blades and not rotating propeller blades. Since the motion of the blades is contributed entirely by the blades rotation (no forward velocity), Would it be possible to use these equations if I assume the tangential velocity of the blade to be the equivalent airspeed in the equations?
