10
Apologies for the quality. Other snippets from the video show wingtip tanks, but these could be a mod. The most distinctive thing about it that I can see it the side window
This may be the same aircraft, but can't guarantee it
  • $\begingroup$ what/where is the video? $\endgroup$
    – tedder42
    May 17 at 21:17
  • $\begingroup$ The video isn't aviation related, the plane appearred for just a few seconds, the only decent stills from it are here. $\endgroup$
    – Greg Woods
    May 19 at 16:07
23
The aircraft is a 1971-1976 Cessna 421B. Here is why:
The pilot side window vent identifiers this as a pressurized Cessna 400 series which means Cessna 414 or Cessna 421.
The Propellor hub looks like it has a higher thrust line, and is attached to a geared engine, which means it has to be a Cessna 421. If the engine is not geared, it may be a Cessna 414.
The tip tanks are stock Cessna tanks. Which came on many models.
The long nose narrows it down to a Cessna 421B because the Cessna 414 with tip tanks had a short nose. The Cessna 421B was manufactured from 1971 to 1976.
Wikipedia Cessna 421B photo enter image description here
  • $\begingroup$ Those geared engines are run sooooo hard. $\endgroup$
    May 17 at 22:40
  • $\begingroup$ Superb answer. Thanks for sharing the reasoning behind it $\endgroup$
    – Greg Woods
    May 18 at 22:25
  • $\begingroup$ I swear that triangular window looks like a "wing window," common in cars of the era. I know it's not one, but still. $\endgroup$ May 19 at 1:06
It appears to be a Cessna 421. (Source)
