on the airbus A320 while taxing, does applying rudder and tiller sum up the turn? if so where is it mentioned
Yes. The pedal order is summed together with the commands from the two tillers. However, a pushbutton installed on each tiller allows the pilot to temporary exclude the rudder part of the input.
Usually in the FCOM under "Landing Gear". See for example page 30 here
Extract from link above:
  • $\begingroup$ Thank you for replying, but page 30 does not mention tiller + rudder is added. It only tells tiller n f/o and capt side is algebraically added $\endgroup$
    – Deepak
    Apr 30 at 17:31
  • $\begingroup$ @Deepak there is a diagram on the next page $\endgroup$
    – sbabbi
    May 1 at 17:44
