I have a question regards to the following formula related to Blade Element Momentum theory for the application to calculate on airplane propellers:
$$ dQ=4\pi r^3 \rho V_\infty(1+a) a' \Omega F dr $$
where
- $Q$ = angular momentum
- $r$ = radius
- $V_\infty$ = aircraft's forward velocity
- $a$ = axial inflow factor
- $a'$= angular inflow factor (swirl factor)
- $\Omega$ = angular velocity $\left(\frac{2\pi n}{60}\right)$
- $n$ = rotations per minute
- $F$ = prandtl tip loss factor
As a result of using the tip loss factor which are numbers between 0 and 1 the end result of the calculated torque Q is lower. I have sincere trouble understanding what this means. Either the propeller runs with less resistance meaning that the propeller will run faster (higher rpm's) while keeping the engine power constant. (Shaft torque is equal) Or There is a loss in torque which means the engine has to deliver a higher torque and so the propeller runs slower (rpm's go down) while keeping the engine power constant. (Shaft torque is then not equal)
Which is the case? If it is the latter, then how is the torque calculated that the engine needs to be able to deliver?
In case of a wind turbine I somehow find this much easier to understand. There is a certain amount of power delivered by the wind. After the tip loss correction has been applied the resulting Q can directly be used to calculate the expected power output.
