Why is it that trailing edge flaps are only used at lower speeds?
Can they be used at higher speeds too?
Sign up to join this communityNormally flaps are only used to increase drag and lift for low speed operation. There is no benefit to extending them at higher speeds, where they just reduce efficiency, and they generally aren't designed structurally for high speed operation, with a few exceptions.
Some fighters in WW2 had a "maneuvering flap" setting that could be deployed at speed temporarily to allow tighter turns. The P-38 Lightning had this feature, operated by a switch on the control column.
In rare cases a pilot may want to extend flaps slightly to effectively change the wing incidence to reduce the deck angle in cruise. You could do this with the DeHavilland Beaver. If you wanted to, you could cruise with the flaps extended about 5 degrees, when flying with heavy loads, to reduce the nose attitude. If you're in a Beaver on floats that is near max gross weight, the drag penalty from a few degrees of flap (which includes aileron droop) is not that great. Not a common practice though.
Lowering the flaps puts stress on the flaps and their attachments to the wings, and also increases the loading on the wing. Extending flaps at too high an airspeed can damage the flaps, their attachments, or the wings.
Beyond a certain airspeed, the stress can even cause the flaps to separate from the wing. Naturally, this will make it much harder to control the airplane and should be avoided.
