Why do some have an F and others have a D?
1$\begingroup$ What is the source of the image? What else can you tell us about it (what airspace does it show, etc.)? $\endgroup$– TypeIAMar 18 at 18:24
$\begingroup$ @TypeIA It is Sarasota airspace. It is from this Vasaviation video. youtu.be/Wsf6zzmzH8c $\endgroup$– Boeing787Mar 18 at 18:33
1 Answer
Those letters indicate the wake turbulence category of the aircraft.
Based on context—LFA
, callsign "BUCKY," is a flight school and is unlikely to by flying "Upper Large" aircraft—the categorization being used in the video is probably the "Wake Turbulence Recategorization" (RECAT) rules, which is an older version of of the wake recategorization project (see FAA JO 7110.659C, the latest version of RECAT in use before its cancellation). The current standard is known as "Consolidated Wake Turbulence" (CWT) and procedures are defined in FAA JO 7110.126. The wake turbulence category of a particular aircraft type can be found in FAA JO 7360.1. If you had taken the screenshot at a slightly different time the datablock would have shown the aircraft type in the righthand side instead of the groundspeed.
Note also that this is NOT a depiction of a real-world FAA system; VASAviation feeds ADS-B data into their own simulator software. It looks pretty close but you cannot assume it is the same thing that the controllers were seeing at the time.
$\begingroup$ Do you know what the F and the D by the speed indicate? $\endgroup$ Mar 18 at 22:13
3$\begingroup$ Yes, and I said that in my answer... "F" indicates RECAT category F and "D" indicates RECAT category D... $\endgroup$ Mar 18 at 22:36
