-1
I was curious about the difference between the 777-200 LR and the 777-200 ER
ER stands for extended range
LR stands for long range
What's the between them difference? Why have two variants which do the same thing? And if one has a longer range than the other, why didn't they just use that one instead of doing both the ER and the LR? And any performance differences?(Takeoff Distance, Landing distance)
The Boeing 777-200ER is an upgrade of the original -200 variant with higher fuel capacity and MTOW (maximum takeoff weight). It is otherwise quite similar to the original variant. The 777-200LR is however part of the second generation of the 777 (along with the 777-300ER and 777-200F), which received a new wing with ~4m larger wingspan and is exclusively powered by the second generation GE90 engine (the -200ER has the option to use the PW4000, RR Trent 800 or first generation GE90). This gives the -200LR a significantly higher range:
777-200ER 777-200LR
Introduced 1997 2006
Wingspan 60.93 m 64.8 m
MTOW 297 550 kg 347 815 kg
Max. Fuel 137 460 kg 145 538 kg
Range 7065 NM 8555 NM
(source: Wikipedia)
This makes the -200LR suitable for ultra-long haul flights, while the -200ER is more commonly used for shorter long haul flights:
The B-market 777-200ER ("ER" for Extended Range), originally known as the 777-200IGW (increased gross weight), has additional fuel capacity and an increased MTOW enabling transoceanic routes. [...] As of 2018, 338 examples of the -200ER are in airline service. It competed with the A340-300. Boeing proposes the 787-10 to replace it. [...]
The 777-200LR ("LR" for Long Range), the C-market model, entered service in 2006 as one of the longest-range commercial airliners. Boeing nicknamed it Worldliner as it can connect almost any two airports in the world, although it is still subject to ETOPS restrictions. It holds the world record for the longest nonstop flight by a commercial airliner. [...] The -200LR was intended for ultra long-haul routes such as Los Angeles to Singapore. [...] Airlines operated 50 of the -200LR variant as of 2018. [...] The closest competing aircraft from Airbus are the discontinued A340-500HGW and the current A350-900ULR.
(Wikipedia: Boeing 777)
The Boeing 777X will be the replacement for the 777-200LR and -300ER.
  • $\begingroup$ Had a pilot on the jumpseat years ago who had just finished the 777 type rating course at Boeing, who would soon be flying it for an airline. Asked him about it; he gushed about it being a wonderful airplane; it's only problem: "it holds waaaay too much gas!" $\endgroup$
    – Ralph J
    Commented Mar 12, 2023 at 14:46
