What are the names by which runways are classified according to the configuration of the placement of the approach lighting systems? (I'm not talking about HIALS or HIALS-II because those terms are used for so many configurations) enter image description here
  • $\begingroup$ In the Airport diagram, we see that the approach light systems for the two runways are represented by different symbols. The reason why these symbols are different is that the placement and configurations of the lighting systems are different. So what are the names of these different configurations? That's what I was asking. $\endgroup$
    – pilot162
    Jan 31 at 16:38
Here's the reference material for US airports. I suspect from your airport diagram that you may not be referring to US:
Figure from the US AIM (Aeronautical Information Manual), located online here.
Figure from the FAA Digital Terminal Procedures Supplemental
From the Chart Supplement Legend
  • $\begingroup$ Thank you for your answer but I need to ask that to be sure about it, ALSF is the equivalent of HIALS and ALSF-II is the equivalent of HIALS-II? Am I right about that? $\endgroup$
    – pilot162
    Jan 31 at 17:40
    $\begingroup$ In the US I haven't seen a reference to "HAILS-II" so I am not sure. The FAA breaks approach lighting systems in "High Intensity Approach Lighting Systems" and "Medium Intensity Approach Lighting Systems." ALSF-2, ALSF-1, SSALR, SALS and SALSR are all considered "High Intensity" systems. MALS, MALSF, MALSR, SSALS, and SSALF are all medium intensity. $\endgroup$
    – Max R
    Jan 31 at 18:05
  • $\begingroup$ The ICAO system in Europe is trying to copy from the US FAA, but unfortunately many things are missing. Thank you very much for your answers. $\endgroup$
    – pilot162
    Jan 31 at 18:16
