I noticed that the gust lock position differs for some DA40 aircraft..what are the reasons for such difference in mechanical design?
    $\begingroup$ Is the mechanical design actually different? I.e. are there actually two different models, one for left and one for right? From the answer below it would appear the lock is ambidextrous and capable of being installed on either control stick. $\endgroup$ Jan 23, 2023 at 23:54
The AFM indicates that the gust lock must be wrapped once around the stick and the rod engaged with the pedals fully slid back:
enter image description here (source)
it does not specify which side it is to be mounted on although the AFM depicts it on the pilots side there is no requirement for it to be mounted there and it fits fine in the other orientation.
