Why does the plane yaw when the rate of turn is not suitable to bank angle in a turn? In a slipping/skidding turn, there is an imbalance of centripetal/ centrifugal force. How does that cause a yaw?
    $\begingroup$ Actually-- should have asked first-- what do you mean by "yaw" anyway? Are you talking about a change in yaw rate, to some inappropriate value? Are you talking about a deflection of the yaw string? Virtually every turn involves yaw, it's not only a feature of slipping or skidding turns. So that makes your question a bit hard to understand. $\endgroup$ Jan 22 at 16:27
  • $\begingroup$ This just has to be a dupe…. Have you looked for answers?! $\endgroup$ Jan 22 at 16:49
  • $\begingroup$ Yaw : nose turning into turn in a skidding turn, putt of turn in slip turn $\endgroup$
    – guy katz
    Jan 22 at 19:17
    $\begingroup$ It appears to me that this question has essentially been replaced by a similar but potentially better thought-out question aviation.stackexchange.com/questions/97114/… . The present question should probably be closed or deleted. Normally we discourage deletions of questions with existing answers, but in this case it might be appropriate. $\endgroup$ Jan 23 at 12:49
  • $\begingroup$ @quietflyer, I agree these are basically identical questions, so why did you put so much effort into answering both of them? We ought to be voting to close duplicates, not assist in their propagation. And really both new questions have been answered to death already. Voting to close. $\endgroup$ Jan 23 at 18:20
If you mean why does the plane slip or skid when the rate of turn is not suitable to bank angle in a turn, then see item #5 below.
It really doesn't.
Here's a better way to think about slip and skids and the resulting imbalance in forces--
The "causal chain" goes like this--
  1. Airplane nose is not fully aligned, yaw-wise, with actual instantaneous direction of travel, generally due to some aerodynamic yaw torque (for example due to "adverse yaw" from the deflected ailerons and/or from a non-zero roll rate, or due to an intentional rudder input by the pilot) that counteracts the aircraft's natural "weathervane stability" or "directional stability". Yaw rotational inertia can also play a contributing role as a turn is being initiated (or exited), but this effect is generally slight.
(This "misalignment" between nose and instantaneous direction of flight path is sort of but not exactly the same as the yaw rate being "wrong" for the bank angle.)
  1. Side of fuselage is exposed to free-stream relative wind
  2. Airflow hits side of fuselage and generates a real, tangible aerodynamic force
  3. The net aerodynamic force vector is no longer pointing straight "up" in the reference frame of the banked aircraft, as it would be if the wings' lift vector were the only unbalanced aerodynamic force at play.
  4. This causes a reduction (or increase) in turn rate so the turn rate is now "too low" (or "too high") for the bank angle.
  5. This also causes the slip-skid ball to ride off-center.
Note that either item 4 or item 5 can be viewed as the fundamental "cause" of item 6, depending what reference frame we use. Item 4 rather than item 5 is best viewed as the cause of item 6 if we are using a valid inertial reference frame -- e.g. the earth, not the moving airplane-- in which case our explanation should not invoke the fictitious "centrifugal force".
Note that for the exact same degree of "misalignment" between the aircraft nose and the actual instantaneous direction of the flight path-- i.e. the exact same displacement of a "yaw string"-- the resulting amount of aerodynamic sideforce generated by the airflow against the fuselage, and the resulting displacement of the slip-skid ball, and the resulting change in the turn rate, will vary according to the shape of the fuselage and the amount of side area therefore presented to the airflow. So a given deflection of the yaw string will cause a different deflection of the slip-skid ball in various different aircraft.
Note that by putting item #1 at the very front of the "causal chain", we're well equipped to understand why appropriate rudder inputs are the key to preventing slips and skids.
Note also that this perspective works well even for extreme cases, even including 90-degree-banked "knife edge" linear flight such as we see at airshows. Some other "explanations" that we read in pilot training materials tend to break down in such extreme cases.
  • $\begingroup$ There are many related ASE answers that go into this topic, especially the exact cause of the deflection of the slip-skid ball-- will post some more when I get a change. $\endgroup$ Jan 22 at 15:31
  • $\begingroup$ There's another perspective that can be taken here -- at least in a steady-state situation, the only way the yaw rate (or the turn rate) can be "wrong" for the bank angle is if something is creating a real aerodynamic force that speeds or slows the turn rate. And what would that "something" be? Item #4 above. So yes it's "true" that we get a slip or skid if yaw rate or turn rate is "wrong" for the bank angle-- but as for why-- see this answer. Will try to condense this comment into a useful footnote-- $\endgroup$ Jan 22 at 16:04
    $\begingroup$ "There are many related ASE answers that go into this topic, especially the exact cause of the deflection of the slip-skid ball". Recommend you find one and VTC. $\endgroup$ Jan 22 at 19:09
