I am a Swiss citizen and I might have to move to the US for a couple of years. I own a small plane in Switzerland (HB-registered) and I'd like to take it with me to the US. As my stay in the US would be for a relatively short period of time, I'd like to keep it HB-registered. Is it possible to do that knowing that the plane would be based and primarily used in the US for that period of time?
  • $\begingroup$ I can't find any kind of maximum duration visit in 14 CFR. I'd recommend calling the FSDO nearest your intended location. $\endgroup$
    – Max R
    Jan 19 at 22:48
    $\begingroup$ Here is the website with contact information for the FAA Aircraft Registration Branch in Oklahoma City, OK. They should be able to help you: FAA Aircraft Registration $\endgroup$
    – user22445
    Jan 19 at 23:38
  • $\begingroup$ I would recommend comparing the cost/effort of getting your plane across the Atlantic (twice) compared to renting something once you are in the US $\endgroup$ Jan 20 at 17:59
  • $\begingroup$ @MaxR thanks for you advices I will definitelly contact them! $\endgroup$ Jan 21 at 19:20
  • $\begingroup$ @757toga thanks for you advices I will definitelly contact them! $\endgroup$ Jan 21 at 19:20
