In radar surveillance we use primary and secondary surveillance radar for different purposes. I'm wondering about the antenna that use in both system:
- Secondary Radar uses an array antenna
- Primary Radar uses a reflector
Why the different designs?
With the secondary system, you are simply sending a one-way message from the radio tower to the transponder in the plane, and the transponder is transmitting a message back from the plane to the radio tower. It is a very simple two-way radio conversation between relatively high powered stations.
With primary radar I am sending out a signal and all I am receiving back is the nearly microscopic amount of energy that bounced off your aircraft. That signal may be hundreds of thousands--or even millions--of times weaker than the secondary signal being transmitted by your transponder.
From an engineering perspective, the primary receiver is designed to solve a far, far more difficult task, hence the more complicated antenna requirement.
