You need to think about what are the constraints and what are the variables. If bank angle is a "given" (i.e. constrained) but turn radius or rate are not, and the airplane is constrained to remain in horizontal flight (not climbing, and especially not "pulling G's" to curve the flight path ever-more-steeply-upward in an approximation of the start of a loop), well, then for any given bank angle, why should increasing the airspeed increase the load factor?
Keep in mind that for any given bank angle, every extra knot of airspeed mandates a decrease in the angle-of-attack of the wing in order that the flight path remain horizontal rather than starting to curve upwards. So why should the load factor increase?
At the end of the day, if the only "givens" are bank angle and the fact that the flight path must remain horizontal, then the flight dynamics don't "care" about airspeed at all as far as load factor is concerned. The load factor will always equal (1/ (cosine (bank angle))).
On the other hand, if turn radius or turn rate is included as one of the constraints, and bank angle is not, then everything changes: an increase in speed will mandate an increase in bank angle and load factor.
If airspeed increases, doesn't lift increase, which should increase
the load factor? I'm missing something here about the calculation of
the forces of lift, but I'm not sure what.
You are missing that the angle-of-attack is not constrained to be constant, but the flight path is constrained to be horizontal, and that's why increasing the airspeed doesn't increase the lift force.
P.S. your question didn't actually state that the flight path was constrained to remain horizontal. But in the absence of information to the contrary, that's pretty much presumed (though it really should be stated explicitly). If the airplane is allowed to start entering a loop as soon as we increase the power, then situation becomes immensely more complex, and since we aren't given any explicit constraints on angle-of-attack (e.g. a-o-a is presumed to remain constant?), we're basically left with an unsolvable (insufficiently constrained) problem.
