Why some airways, (example T358) are drawn in blue, while other (example V44) are drawn in white?
I can not see any difference between blue and white airways, step between waypoints, direction and altitude restriction looks similar.
Sign up to join this communityWhy some airways, (example T358) are drawn in blue, while other (example V44) are drawn in white?
The airways depicted in white on the presentation (map) in your question are "VOR" Airways. Note they are preceded with a "V." (e.g. V378-499) They are routes between VOR ground stations. Depending on the type of map you are looking at the VOR Airways could be depicted in black (but will be preceded with a "V").
The blue airways depicted are low altitude RNAV (Area Navigation) routes. Note they are preceded with a "T" (e.g.T358). RNAV routes are not dependent upon ground stations.
