You can likely find all the answers in 14 CFR Part 145 - Repair Stations.
But to provide a somewhat qualified and summarized answer to your question:
Per Subpart D - Personnel:
- The stations is required to have an Accountable Manager, responsible
to ensure an adequately trained and certificated staff is in place to
do the work.
- Supervisory personnel directly in charge of all the work to be done
and which are required to be certificated as a mechanic or repairman
under Part 65. Individuals performing the work under that supervision
must be trained, but are not required to be certificated.
- Properly trained inspection personnel.
- A person certificated as a mechanic or repairman under Part 65
authorized to approve an article for return to service.
- If they choose to use repairmen, they must certify that the each
person recommended to receive a repairman certificate, a) Is employed
by the station, and b) meets the eligibility of Part 65.101.
You might want to also review Part 65 Subpart D - Mechanics and Part 65 Subpart E - Repairmen to understand the difference.
As a note to the second bullet above; from § 145.3 Definition of Terms:
(c) Directly in charge means having the responsibility for the work
of a certificated repair station that performs maintenance, preventive
maintenance, alterations, or other functions affecting aircraft
airworthiness. A person directly in charge does not need to physically
observe and direct each worker constantly but must be available for
consultation on matters requiring instruction or decision from higher
authority.
